Rotus 7 Update:
The car is painted .. black .. now I am putting the suspension back together ..
Still need to fix and paint the fenders .. and put the dash back together ..
Sandblasting parts today!
Rob
Previous Project Rotus thread:
http://www.usa7s.com/vb/showthread.php?t=249&highlight=project+rotus&bcsi_scan_7D0B2490BCFE64B4=A41KHbJfHaAw825FJsperwsAAAC+7XIM&bcsi_scan_filename=showthread.php
Edited by solder_guy
  • Replies 46
I must say that I am jealous. I have sold mine only because I lost my job at the end of the year and have had to live off of my toy money per my wifes rules. If I can find something soon I will be back in the game sooner than later. I am starting to have major withdrawl. My Merkur XR4TI just doesn't do it for me like a 7 does.:7rain:
Robert, the XR4TI makes a great donor. Just find a wall to run into, and say " Honey, I wrecked the car today" . Russ
  solder_guy said:
Rotus 7 Update:
Rob
Any pictures? I'm 50/50 on black right now.
sounds like you might be in the market for some grey paint... :D
Hay Mazda,
Black shows every speck of dust and dirt plus any imperfections in the body work...(ripples, dents, waves, etc.) also low visibility at times like at night for those stealth drives without lights..:crazy: :D :jester: you know when the local PD is looking for that little car that just went by at close to the speed of sound and then disappeared around a corrner.:lol: :lol:
Mazda black is a bad color.
http://wrangler.rutgers.edu/gallery2/d/10897-3/Solstice08GXP.jpghttp://wrangler.rutgers.edu/gallery2/d/9766-3/DSC02230.jpghttp://wrangler.rutgers.edu/gallery2/d/9520-3/DSC02101.jpg:jester:
Last week we discovered that my Rack and Pinion was worn .. so I went to the Pullapart Junkyard yesterday and found one on a 1981 Starlet that will fit my car. Got it back to the shop .. took it apart and regreased it and it works perfectly!
Sandblasting parts today in preparation for paint.
Rob
Rob
Don't you have to shorten it?
Not necessary at all! I have no idea why they shortened the rack housing .. the rack itself is not shortened. Fits just fine.
Rob
Rob
Pics of old and new PLEASE. Is the distance between the old and new tie rod ends the same?
Yes! The same ...
Rob
When I sold my car I spoke to guy in California who worked on the rotus project and sai there were a few cars built with a re geared rack that made it steer correctly. He said there were only 2 or hree of them. He believed our cars were the ones. Anything after those cars were "shit". He was interested in buying my car but then balked.
  slngsht said:
Rob, do you have pics of the 2 racks side by side?
Also, what is the length of your rack?
They are mirror images of eachother .. I'll see what I can do tomorrow at the shop ..
I read somewhere that the ratio is 21.7":1 (I'm not sure exactly how to interpret this.)
Rob
Rob
27:1 means you turn it like you're spinning a top, and the car actually turns like an aircraft carrier.
:jester:
THen you could upgrade to a 4 wheel steering sytem.
Well there is a problem .. this new R&P has the pinion rolling above the rack .. which means that the pinion will be connecting to the U joint and steering rod at the height of the Rotus suspension rocker arms .. duh!
Rob
If the pinion is on the wrong side of the rack, I would assume this would reverse the steering unless you swap front to back which side of the front upright the tie rod fastens to. That would be interesting to drive!
