A Mexican woodpecker and a Canadian woodpecker were in Mexico arguing about
which place had the toughest trees. The Mexican woodpecker claimed Mexico had a
tree that no woodpecker could peck.
The Canadian woodpecker accepted his challenge and promptly pecked a hole in the
tree with no problem. The Mexican woodpecker was amazed.
The Canadian woodpecker then challenged the Mexican woodpecker to peck a tree in
Canada that was absolutely 'im-peckable' (a term wood peckers like to use). The
Mexican woodpecker expressed confidence that he could do it and accepted the
challenge.
The two flew to Canada where the Mexican woodpecker successfully pecked the
so-called 'im-peckable' tree almost without breaking a sweat.
Both woodpeckers were now terribly confused. How is it that the Canadian
woodpecker was able to peck the Mexican tree, and the Mexican woodpecker was
able to peck the Canadian tree, yet neither was able to peck the tree in their
own country?
After much woodpecker pondering, they both came to the same conclusion:
Apparently, your pecker gets harder when you're away from home.
You need to get your car finished. :7drive:
Then a good blat will test your peck,...er, pucker factor. :)
m
Dude, you ain't kidding.
Mazda, I'm getting tired of being the only 7 at the area shows. 1 is a lonely number. Would it help if I came by and let you drive mine?
:ack:
man, i can't buy a break. my plasma crapped out again. back to cutting by hand. plasma is so sweet when it's working, i'm dreading cutting sheet metal with any other tool.
Having Murphy's Law interested in the project really tends to prolong things.
I had spent the last year accumulating $3ks worth of parts to rebuild the engine in my E30 M3. This is my other track rat because the BMWCCA won't allow open cars (my Birkin) in their HPDE events.
So in late may I start rebuilding the bottom end in my living room. Early june, I decided to buy some ARP Conrod bolts. Those arrived about a couple of days before the Cedar river decided to flush the sewers and proceed to flood the house up to the ceiling ( 9ft above ground).
I lost most of my electronic tools, and am now still cleaning my hard tools and trying to repair my electric tools. I also lost some parts for a Megasquirt EFI conversion for the Birkin in the flood. ...And Summer is fleeing. :banghead:
m
m
My problems are trivial compared to yours :cheers:
This one pecked a hole in the tree out back last year. Is this a Mexican or Canadian woodpecker? It sure was big and loud. :D Tom http://usa7s.com/aspnetforum/upload/1068825575_1.jpg
