Hank Posted February 26, 2009 Posted February 26, 2009 The local instrument tech working on my Megabusa wiring is swamped with work and his wife had a baby last week. I don't think he'll ever finish it. I'm willing to trailer my car somewhere in the Gulf Coast area to get the wiring harness properly sorted. Part of the wiring harness needs to be extended to allow the ECU to be mounted in the passenger side footwell. The only add-ons from the factory Hayabusa & Westfield harnesses are a Flaming River safety/battery kill switch and a GI Pro gear indicator/timing retard eliminator. Let me know if anyone is recommended to do the job. Thanks in advance. Hank
DB6 Posted February 26, 2009 Posted February 26, 2009 Hank, Damn ,your car seems like an awful lot of work, is Westfied UK or the dealer in the USA helping with what seem to be problems you should not have to figure out on your own? Dear me.
Hank Posted February 27, 2009 Author Posted February 27, 2009 Well, it is partly my fault. I could have simply sent the loom to Westfield for modification. However, Westfield does not use the factory dash for anything. I want to use the factory Hayabusa dash for the speedometer and tachometer. So, it is somewhat hybrid than what others do. Some have done it in the past, but they are all in Europe. To add to my dilemma, no one in my area works on custom wiring harnesses. The street rod crew order Painless wiring kits and the motorcycle racers remove and install factory wiring harnesses in their drag bikes. My situation is definitely unique in that part of the harness needs to be extended so that the ECU can fit in the passenger footwell on a hinged plate that pivots down from the Scuttle behind the dashboard.
JohnCh Posted February 27, 2009 Posted February 27, 2009 Hank, Why don’t’ you tackle this yourself? If you are just extending the loom and tapping in a few components it isn’t that hard. I built the engine loom for my Emerald with no prior experience and it is about 4 years old and still going strong (I should know better than to tempt fate by writing that :banghead: ). I’m sure there are folks here who can steer you through the process. -John
Hank Posted February 27, 2009 Author Posted February 27, 2009 I really wish I could but I'm up to my eyeballs in website work right now and I want the car finished at the same time. From the outside looking in it seems crazy, but I can't find the time to go in the garage and finish it.
DB6 Posted February 27, 2009 Posted February 27, 2009 I was looking at your site, I tell you what Hank, that car is a lot of work, hats off to you and all...but did you expect to have to do so much work and mods to get this far? Regards David
Hank Posted February 27, 2009 Author Posted February 27, 2009 David, Sure, there were "tests" along the way, but this car isn't exactly going to build itself. That's the fun in purchasing a kit car. If everything was slide tab "A" into slob "B" it wouldn't be fun, right? Keep in mind I'm customizing the car as I go. The paddle shift setup is on its way from Britain right now. The reverse box is getting ripped out before the first mile is put on the chassis. In its place will be an alternative that I will post about after completion. It's been fun up until a month ago. Now I want it done. The wiring kid had it for a month and I think he spent 3 hours on it.
DB6 Posted February 27, 2009 Posted February 27, 2009 Hank, Myself, the older I get, the more I like slot A into B, then change it later. If you had built your car as per stock would it have been a lot easier? are your [problems self inflicted you think? I did not study your whole build site but from what I saw, it seemed to me like a hell of a lot of work for you to correct many basic assembly faults that should have been corrected by the factory.; or at the very least helped you out a bit more. By the way, do you have a reverse gear, is that a problem if you do not and need to register the car; and finally ,what was it that drew you to the bike engined 7, I mean if the reg 7 is on the edge, bike engined 7's are jumping off the cliff.
Hank Posted February 27, 2009 Author Posted February 27, 2009 David, The only hiccups I had along the way were as follows: 1. Missing brake master cylinder fittings (2) 2. Steering shaft was for a fixed steering wheel and I specifically ordered a detachable steering wheel mount 3. Dry Sump tank fitting - I only used the Westfield dry sump tank. I used the SBD dry sump system. I knew the revisions required ahead of time. 4. Roll cage side mounts. Sure I could have removed the lower body section to mount the inner roll cage mounts, but I chose not to. I agree with your statement that if I had wanted the Megabusa completely stock it would have been completed a long time ago. The bulk of the build took only 3 weeks. I waited on the wheels for 3 months. Other bits took additional time (brake fittings, shoulder harness spacers). I will leave the reverse box in for certifying the car for road use by the State Police. They do not require me to drive it. I was told on the phone if it passes inspection on my trailer that I would be issued a registration shortly thereafter. After the registration is printed and I get an inspection tag I will drop the car off to get the reverse box removed. Then I'll update my website with what I replaced it with. What brought me to get a Megabusa? I like challenges. I like power-to-weight ratios. I love the sound of motorcycle engines over blatty 4 cylinders. Now turbo 4 cylinders, that's a different story. I might turbo the Megabusa and have the best of both worlds. Of course the reliability might be thrown out the window. Hank
DB6 Posted February 27, 2009 Posted February 27, 2009 Hank, God's speed, I hope it works out. BTW, from my own experiences I find the police are far nicer when the car is stationary....lol;)
Hank Posted February 28, 2009 Author Posted February 28, 2009 Car is back home and safe in my shop. I've contacted a few locals. :nopity: Pray for me. :grouphug:
BusaNostra Posted February 28, 2009 Posted February 28, 2009 Hank----I did the same thing to my hayabusa turbo wiring (Westfield of course). I placed the ECU under the passenger area. Yes, you need to extend the wires to reach the projected area. Took me night and day to accomplish the job. Buy a couple of 18ga wires (diff colors) & bunch of butt connectors. The first step I did was to unwrapped the Busa stock harness. Identify which wire or sensor wires that needs to be extended. You have do it carefully and accurately. Never cut more than two wires. "Cut, extend, solder & label" You will make it, its just tidious.
TurboBird Posted March 5, 2009 Posted March 5, 2009 Hank, I turbo'ed my Blackbird BEC 4 years ago; I only street drive and have no reliability issues so far. I have a Quaife reverse box which has held up so far (~18k miles total, ~8k with the turbo) although I don't like the amount of lash it adds to the drive train. I'll be interested to see your reverse solution when you finish.
