Are you looking for a tire pressure gauge for the 7 only or do you have any other applications? Do you do any racing?
If you're looking for a 7 guage, I'd look for something that reads from 0-30psi and has an accuracy of at least .5 psi. I really like digial gauges because there's no fudging the numbers.
If you do any racing, I'd look for something that's accurate to closer to .1psi. When comparing accuracy, it is important to read the fine print. Many gauges on the market advertise accuracy to a certain percentage of full scale or capacity. This means that a 100 psi gauge accurate to 1% of full scale can be off by one full pound (1% of 100) anywhere on the scale. At 14 psi, the gauge could display anywhere from 13 to 15 psi.
In gauges you can choose 2 of these 3:
Large Operating Range
Cheap
Accurate
