I am looking to replace my red Luke 5-point harnesses with some similar Schroth ones and wondered if anyone else is using this type (I plan to go for the Profi III)?
I know that in the UK companies offer shorter belts for the 7s and wondered if anyone had been down this road before with Schroth? I have an Email into them but not heard back yet. I would rather not have to trim the belts if possible.
Many thanks
James
I replaced Sabelts with the Profi II and am very happy with them. The webbing is more pliable and consequently more comfortable. They also have a version available that allows you to change the lap belts from pull-down to pull-up configuration. I use the latter on the passenger side since it is easier when I buckle in a passenger for their first ride, while I prefer the pull-down setup for my side of the car.
-JohnJohnCh2007-01-10 07:05:26
Thanks very much John - did you get the standard length ones and did you need to trim them at all so you are not overwhelmed with too much fabric? also, did you go for the bolt or snap ends?
Thanks
James
Standard length. I simply rolled up the excess from each shoulder belt and then affixed that roll to the top of the belt with a tie wrap.
I am using bolt-in set up, which works a little better in a Westfield. BTW I have a spare set of the Profi II ASM 4-points (they accept sub belts) with the road legal buckles. When I originally bought them, I didn't realize that the flexibelt technology, which gives the pull-down/pull-up flexibility, was not available with that buckle. To make a long story short, I never had time to return them for a refund ,and then forgot about it. The belts are brand new, in the boxes, but were purchased about 2-1/2 years ago. PM me if you are interested.
Thanks,
John
