Does anyone have the Fram # for the oil filter on a standard 1700 Crossflow?
Thanks in advance
Just look up a 72 pinto. It will be the same.
I can give you mobil 1's pn when I get home. Doesn't matter much which filter you use - just make sure you use oil with a zinc additive!
