twobone Posted August 26, 2010 Share Posted August 26, 2010 Both my front brakes are dragging. Likely culprate is a dirty caliper piston sleeve? What else might you recommend? I assume this is not dangerous other than the risk of disc warpage and fast deterioration of pads? Link to comment Share on other sites More sharing options...
Ian7 Posted August 27, 2010 Share Posted August 27, 2010 Do you have dual-piston calipers (ie caliper fixed and pistons on both sides of disk move), or a simpler (cheaper) street car style where one piston moves and the caliper also moves on sliders? very common for that type of caliper to seize up on its bushings and not relax once applied. Link to comment Share on other sites More sharing options...
BMW RACER Posted August 27, 2010 Share Posted August 27, 2010 How bad are they dragging? Can you feel them stop the car when you have your foot off the brakes? Link to comment Share on other sites More sharing options...
twobone Posted August 27, 2010 Author Share Posted August 27, 2010 No, just squeeling/chirping. It is coating my wheels with brake dust. Link to comment Share on other sites More sharing options...
jlumba81 Posted August 27, 2010 Share Posted August 27, 2010 How much pad life is left? Squeeling is usually a sign that they are low. Try spraying some silicon lube under the caliper pistion seal. Link to comment Share on other sites More sharing options...
