G2sound Posted October 30, 2010 Share Posted October 30, 2010 Does anyone have or know where I can find an Idler Pulley assembly for a ZX3 Zetec? I am building up a crate ZX3 to replace the ZX1 in my S1 and have read that an Idler pulley is necessary in order to make the water pump run in the correct direction. I found one on the Raceline site, but two emails to them have yielded no replies. Do they do business with customers in the USA? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Paul Hill Posted October 30, 2010 Share Posted October 30, 2010 (edited) You might try calling them..... for some reason some outfits in the old country are not as email friendly as we are on this side of the big pond. I have not personally dealt with them but know of quite a few who have bought pieces from them recently. I built my own surpentine assembly using parts bought from NAPA when I put a Zetec in my Europa. Had to fab a few mounts but it certainly wasn't rocket science. If you weren't so far away I'd be interested in your ZX1! Edited October 30, 2010 by Paul Hill another thought Link to comment Share on other sites More sharing options...
JohnCh Posted October 30, 2010 Share Posted October 30, 2010 Raceline is very hit and miss with email, but when you get them on the phone, they're quite helpful. -John Link to comment Share on other sites More sharing options...
RossD Posted November 1, 2010 Share Posted November 1, 2010 (edited) Can't you just swap the water pumps? Check zetecinside.com Edit: Try theses guys: http://qsraceengines.com/ Quicksilver RacEngines. They might have a solution Edited November 1, 2010 by RossD Adding link. Link to comment Share on other sites More sharing options...
G2sound Posted November 1, 2010 Author Share Posted November 1, 2010 Can't you just swap the water pumps? Check zetecinside.com I've looked into changing out the impeller to run the water in the opposite direction. Seems that the problem is that the pump body is designed for water flow in a single direction. Can cause cavitation, thus reduced water flow if you run the water in the opposite direction. I'll try giving Raceline a call. Thanks! Link to comment Share on other sites More sharing options...
slomove Posted November 1, 2010 Share Posted November 1, 2010 Can't you just swap the water pumps? Check zetecinside.com Edit: Try theses guys: http://qsraceengines.com/ Quicksilver RacEngines. They might have a solution That was an easy solution for the ZX1. Ford had European water pumps with reversed impellers for cars without air condition and simplified serpentine (certain Fiesta and Escort models). The pump was definitely made for such an impeller and I use it for a long time. Not sure if that was ever done for the ZX3. Link to comment Share on other sites More sharing options...
