slngsht Posted March 23, 2007 Posted March 23, 2007 Any good free ones out there? I actually started playing with my own - just to play around... so far I have the roll center calculation down, can rotate the frame, calculate lower ball joint position. I kinda stopped at the upper ball joint, but it's not that hard. Of course my little model doesn't do anything with steering, etc... and since I can see how it all works, I'm not as motivated now http://www.usa7s.com/aspnetforum/images/emoticons/lol.gif So, I just want to play around with one that's already working before fabbing up my front suspension. The only free one I know of is "wishbone" which is DOS based.
slomove Posted March 23, 2007 Posted March 23, 2007 Come on, we are professionals..... You need > this http://www.usa7s.com/aspnetforum/images/emoticons/biggrin5.gif You don't even need to drive your car anymore. Just simulate the fun http://www.usa7s.com/aspnetforum/images/emoticons/cryin.gif Gert
slngsht Posted March 23, 2007 Author Posted March 23, 2007 good lord man. I already spend too much time on the computer http://www.usa7s.com/aspnetforum/images/emoticons/lol.gif
scannon Posted March 23, 2007 Posted March 23, 2007 There is a suspension design spreadsheet available on the Miata.net forum. I haven't used it so I don't know how good it is. http://forum.miata.net/vb/showthread.php?t=32121 Skip
slngsht Posted March 23, 2007 Author Posted March 23, 2007 Thanks Skip. I think that one helps with roll bar, etc... I'm looking for one where I can design the general suspension layout. I will keep that one handy though. http://www.usa7s.com/aspnetforum/images/emoticons/cheers2.gif
slngsht Posted March 25, 2007 Author Posted March 25, 2007 Still playing around with this... I need to finish doing the contact patch calculation to get a better roll center result, but things are looking promising. My calculations are still off compared to an off the shelf program that I have, but all the basics should be correct, so it's a matter of debugging what's going on. Here are a couple of screenshots of a little graphic I put together to visualize what's hapenning. http://www.usa7s.com/forum/uploads/20070324_215047_RollCenter1.JPG http://www.usa7s.com/forum/uploads/20070324_215129_RollCenter2.JPG
slngsht Posted March 27, 2007 Author Posted March 27, 2007 http://www.usa7s.com/aspnetforum/images/emoticons/hurray.gif significant improvement tonight... My numbers are very comparable to Roll Center Calculator by Performance Trends http://www.usa7s.com/aspnetforum/images/emoticons/thumbsup.gif At 4 degrees roll, with the same setup, they get: RC(X,Y): 3.8,3.7 Camber left: -1.15, right: -5.22 I get RC: 4.04,3.69 Camber left: -1.14, right=-5.21 I need to improve the location of contact patch in my program, as I did a quick and dirty calc on that one. Everything else should be dead on. This was a little easier than I thought. http://www.usa7s.com/forum/uploads/20070326_220015_RollCenter3.JPG
bsimon Posted March 27, 2007 Posted March 27, 2007 http://www.mitchellsoftware.com Pretty good stuff, although 500 clams might be a bit out of range for most of us. You can get a no-save demo version with Warren Rowley's book "An Introduction to Race Car Engineering" at; http://www.rowleyrace.com/publications.htm If you are serious about suspension design, the Rowley book is a great resource to have around. A bit more detailed than Van Valkenburgh's work.
slngsht Posted March 27, 2007 Author Posted March 27, 2007 I had used Mitchell years ago... in the late 80s
sb427f-car Posted March 27, 2007 Posted March 27, 2007 Are you using macros to change it? I wish I had been a member of Delaware's SAE team (kicks self in arse). I remember one guy messing with excel and macros and had an excellent setup to calc. out all that stuff. Oh well...things happen for many reasons, guess I shouldn't complain. Definately post up your finished excel product. Additionally, there is one on the locost board, but not visual in nature.
slngsht Posted March 28, 2007 Author Posted March 28, 2007 Yes, basically vbscript. Got the pushrod setup working tonight. I think I'm going to stop here - these are the pieces I need for the new front suspension. http://www.usa7s.com/forum/uploads/20070327_232202_RollCenter4.JPG http://www.usa7s.com/forum/uploads/20070327_232237_RollCenter5.JPG
sb427f-car Posted March 29, 2007 Posted March 29, 2007 I've been so busy lately, this has taken a back burner...but please (if you're willing), post up your program!
slngsht Posted March 29, 2007 Author Posted March 29, 2007 I've been so busy lately, this has taken a back burner...but please (if you're willing), post up your program! I want to add a few lines to it and make it available to club members as a benefit http://www.usa7s.com/aspnetforum/images/emoticons/yesnod.gif I have to do some cleanup to it now since I added the bellcrank and pushrod.
