whizzy Posted May 22, 2011 Posted May 22, 2011 Went for a drive today and my ongoing problem with my LHD Westfield girling master cylinder have returned. Low output from the rear port that actuates the front brakes. I am looking for a master cylinder that will bolt up to a 2.250 vertical mount. Any westfield owners that have used something other than a Girling?? If so what did you use and where did you buy it? Thanks in advance! Wendell
bball7754 Posted May 22, 2011 Posted May 22, 2011 Wendell - Here is a possible source for a new Girling, and/or parts. http://www.bugsandbuggies.com/Neal_Grp.asp?Group1=Cylinders&Group_Name=Master+and+Slave+Cylinders Steve
11Budlite Posted May 22, 2011 Posted May 22, 2011 Wendell - If you don't want to use the Girling MC, check out the Tilton models available at Pegasus: [/url]http://www.pegasusautoracing.com/productselection.asp?Product=3505 Pegasus also carries the Girling line and I'm sure the Tilton models are available at other vendors too.
jlumba81 Posted May 23, 2011 Posted May 23, 2011 Wilwood might be a good alternative. http://www.wilwood.com/MasterCylinders/MasterCylinderList.aspx?minorname=Integral Reservoir Compact Master Cylinder
timax Posted May 23, 2011 Posted May 23, 2011 Yep , wilwood do Girling copies or same measurements I should say. Just fitted one and happy enough. ie it works.
