Anyone do a heater bypass with valves on a caterham?
Best options for parts?
Anything special to know?
My 7 had the valves already as the pull lever in the far right corner halts the coolant flow. my feet are surrounded by heat. Engine and tranny to the right, headers on my toes, and exhaust and cat on the left.
I'm RHD so I think I can make a big difference with a proper bypass. Not sure I want to do a cockpit lever system. I may try to rig up a set of t-valves
If your chassis has a later "fresh air" type heater, you can purchase a bypass control valve for it. The control valve automatically bypasses the coolant flow to the heater core. Here.
I think the fresh air heater was introduced in 1988 or so. It can be identified by an air intake that lines up with central lovers in the bonnet. There are two versions of the heater (metal and plastic) but I believe both use the same bypass valve. The bypass valve won't work with the older box heater that draws air from the cockpit
If you've an older box heater, a splice tube and a pair of jubilee clips is the solution.
Of course, you can always bin the heater and raise your power to weight ratio...;)
I'm thinking of something like this. I borrowed this pic from Rob's posting on the for sale forum.
I assume this is no less likely to cause an airlock then a standard bypass valve.
Any downside to this approach?
One thing that I don't understand with this approach is that there are not cutoffs on each side of the heater. Would the heater block still not get as hot as the coolant unless it is shut off completely?
With one heater line blocked by the valve there is no coolant flow through the heater.
Give thought to Not blocking the water circuit.
Plugging a line/flow is likely not the best approach.
IF you must.. then at least cross connect(shunt) the in and out flows/lines.
OR if one wanted to retain the 'bit extra' rad volume of the heater core, simply block the heater's air exits into the car ?
Thanks
I will try to get under the dash and see what kind of vent block I can fashion for the summer.
