Caterham Carpet Set - 1989 DeDion Long Cockpit
11Budlite
Complete carpet set that was removed/never used from a 1989 DeDion long cockpit (the infamous Sugino Seven). According to the original owner it is supposed to be Wilton wool carpet but I have no way of verifying that. I do know that the quality is much better than my Birkin carpet and that it is bound in leather. There are also two leather covered aluminum pieces that go under the rollbar - see 1st photo. The carpet looks as new. Not sure what other years this might fit. I'm looking for $150 + shipping obo. Own a piece of Seven history! :)
  • 3 months later...
  • 5 weeks later...
I've been mulling this over for my 1985 long cockpit, live axle car, but it just doesn't look the same as what I have. Can you pont out the piece that covers the transmission tunnel? Thanks.
MoBoost - The two long pieces in the center of the 2nd photo cover the trans tunnel sides. The tunnel top is listed as a separate piece and has already been sold to another member. Hope this helps.
I have the transmission tunnel top :) that I did not end up using on my car so would be willing to resell that to bring all the pieces together.
It is leather with angular stitching and did have foam backing but as that was shedding, I carefully removed it so it really just neeeds some foam sticking to the reverse. It has a built in gear lever gaiter and goes the full length of the transmission tunnel top.
I have some pictures somewhere but can retake if you want to send me a PM.
  • 2 months later...
