Cyberbug Posted March 27, 2012 Posted March 27, 2012 Does he sequential gear box come with the gear (#) display or can that be fitted so you know which gear you are in? like the WRC cars?
RossD Posted March 27, 2012 Posted March 27, 2012 (edited) If the sequential gear box is a Quaife, then yes. Taylor Race has a price of $875 for it: http://www.taylor-race.com/items.cfm?category=Transmissions&subcategory1=Quaife&subcategory2=Quaife%20Parts&subcategory3=Quaife%20General%20Parts And maybe another $329 for the sensor. Edit: Thinking of a potentiometer attached to the 'drum' with some relays set to pop at specific rotation of the pot to illuminate a number of LEDs corresponding to the number of gears could work. I think...but I'm no electric engineer. Edited March 29, 2012 by RossD locost thinkin'
Croc Posted March 28, 2012 Posted March 28, 2012 You can also buy the gear display for a sadev sequential box - seen one of those on a seven.
Hank Posted March 28, 2012 Posted March 28, 2012 Less than $200 for a gear indicator for a Busa sequential tranny.
Cyberbug Posted March 29, 2012 Author Posted March 29, 2012 thanks guys, The caterham is integrated in the stack display. But I may go with a CSR and installed the sequential later. More learning required on this to pick the right one.
blubarisax Posted March 29, 2012 Posted March 29, 2012 check out Geartronics They have an indicator what will mate up to Sadev or Quaife. Not "that" expensive once you get ofer the cost of the gearbox!
ayseven Posted March 29, 2012 Posted March 29, 2012 http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=180448135142&clk_rvr_id=328032217369 http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=190637477135&clk_rvr_id=328024663364#ht_1194wt_1182
