Project: Triumph Spitfire Mk3 - Busa
Northpole
Hi
I am new here and I hope it is okay for me to post even I am not a Westfield owner...
I am installing a Busa engine in a Triumph Spitfire Mk3 from 1968 and was thinking it would be a good idea to have a stronger clutch. The weight of the car will be with the Busa engine appr. 1200-1300 lbs.
I wanted to share this with the Forum and hopefully I will get some feedback and maybe some good advices on the way?
I am located in Iceland.
Check out the British Locost Builders site. They are the BEC experts. Sounds like a great build, although it might be a bit heavy for a Busa. I know there are Heavy Duty clutches available. Welcome to the world of crazies!!!! Russ
You must have the only 68 Spit in existance that hasn't rusted out. :jester:
My first car was a 68 mklll. Great little car, Bought it in 73 and drove it for 5 years before the frame rusted through.
Just be careful with the Swing Axles. They were also a weak link.
Ah the memories. :driving:
Good luck with your project.
Tom
Pay close attention to the oil and clutch systems. There is a main shaft in the gear box that might also be a good thing to change. Most of the sevens running bec are under 1100, a couple 100 more pounds could really wear on it.
Thanks Russ!
I will find out very soon if this setup is to heavy for the std engine. If so and if I like the car and handling, I will have to look at more power, and as I understand it, this engine is fairly easy to tune.
markus
Tom
Hi Tom and thanks for the advices, are the Swing Axels to weak? I could make them stronger, if they are so week, but again the old engine had alot of torque, I doubt the Hayabusa engine has more.
What about the diff itself? I have heard some say it is strong, some say it is weak probably the ones who has a V8 Rover.
My car was renovated some years ago and is free of all rust :driving:
The frame is very solid and easy to weld some strengthing iron frames in it.
I love the handling, especially after having replacing all the monts with poly and new shocks.
I am little afraid if the diff will hold, any ideas?
Thanks,
markus
Edited by Northpole
Ok thanks, many talks about stronger springs (where can I find/buy them?) and kevler plates in the clutch, but not all do agree, some say the original clutch is best, but I dont know....yet.
Regarding the main shaft in the gear box, what changes are popular and effective?
And what about the oil system? How can I improve it?
markus
Edited by Northpole
The main problem with the old Triumph Spitfire's rear end was it loss of contact patch under hard cornering, leading to some immediate end-swapping. It was fixed in the Series IV Spits with some kind of shackle system on the transverse rear leaf spring. This allowed the spring to compress without "tucking" the rear tire.
I had a 73.
Tom
