Moving Sale Locost/Stalker lights, wings, accusump, fuel lvl etc..
Another military move planned. Before I ebay or craigslist. See the photos, ask questions.. Willing to bundle.
Bonjotwo
I drive to Montgomery Village MD/D.C. from Hampton VA almost every week, through Richmond. Can meet most Fridays and Sundays on 64, 295, 95, 495, 270
$150 Heater. New Heatercraft R08208 Ducted heater set. New. Complete. Now listed at over $300! I will include Four Seasons 74627 Manual Heater Valve ($19). Perfect heater (water w/electric fan) for HOT RODS, JEEPS, off road vehicles, Lotus and Cobra Kit Cars or most any other water cooled engined vehicle. Details here. http://www.jcwhitney.com/heater-kits-fo ... 5c2307u0j1 Shipping, about $18 lower 48.
$150 Steering Rack. NEW Flaming River Ford Mustang II 4" x 4" short steering rack. Still in package. Popular for Stock Cars, Drag, Cobra Kits, Manual Rack Conversions, Hot Rods, Street Rods, and Muscle Cars that use Mustang II/Pinto Style rack. Sold race car and have no use for item. Paid $469 two years ago. New, Still packed in original box. More info - http://www.rjays.com/Flaming_River/racks-01.htm Local pick-up/delivery. Shipping ADD actual costs, around $29
$40 each. 2 American Racing AR 23 wheels. 4x4.75, 3.5 backspace, 15x7". 5 spoke aluminum wheels.
$200. 24-006 - ACCUSUMP 3QT NO VALVE (24-006 $249) New, test fit, still factory air charge w/manual valve
$100. 24-270 - ACCUSUMP ELECTRIC VALVE KIT (24-270 $189)
Electric Accusump Valve kit provides a convenient way of operating the Accusump. They are useful when the accumulator is mounted in a hard to access location. When wired directly into the ignition switch the Accusump can be operated automatically to provide pre-oiling. The kit comes with the electric valve which has 1/2" N.P.T. female threads, a 1/2" N.P.T. pipe nipple, a toggle switch, a length of wire, terminals and installation instructions. Recommended for use in street and pre-oiling applications only.
Add.
T-fitting + check valve $20
Mounting clamps $10
$50 NEW Lingenfelter oil cooler adapter is designed to allow the installation of an oil engine oil cooler on GM Gen IV V8 engines including the LS1, LS2, LS3, LS6, LS7. The LPE adapter is machined from a single piece of 6061 aluminum and is then black hard coat anodized for additional durability. The adapter features -10 fitting for the oil inlet/outlets along with a port for the oil temperature sensor and oil feed line. This adapter was specifically designed to reduce oil pressure drop over other designs on the market, retains the factory oil filter location & includes gasket and bolts. Oil exiting the adapter is filtered oil.
Will not fit 2004-2006 Pontiac GTO.
$65 JAzz 0-90 ohm 11" long fuel cell sender (tube type works with foam) #371-090-03 ($119)
$20 VDO 0-90 Fuel Gauge ($36)
$85 Trick Flow Specialties TFS-8510400 Differential Cover GM 10-Bolt 7.5/7.625 ($143)
$25 Longacre 1.75" roll cage rear view mirror racing stock car ($49)
$20 Generic 16-row oil cooler, new. -10 AN
$50 Hyundai radiator Locost, Brunton Stalker, Westfield, Caterham used, approx 15 miles.
$40 Caterham style front indicator pods, carbon "look" with turn signals Modified to fit Brunton stalker or Locost style mount/perch.
$5 LS Oil level plug
$45 Locost/Lotus seven grill, alumunum
$300. Birkin Rear wings/fenders. New. Primer finish. Never fitted. Drivers side has recess for muffler. $300 local only.
$10 JDM Honda Civic side markers, only the lens housing, no bulb holder.
$10 Wilwood brake fluid level remote reservoirs 2 with mounts, 1 without.
FREE Fuel Level Sender. NEW British standard fuel level/Float Type. 260 Ohms at empty to 20 Ohms full. Free. + Shipping
$25 each 10 Ft push-lock hose. -10 AN oil line have 30 ft.
My error Kevin, I apologize. I need a 1.5" mount. Great price though... Mirror is not going to work for me. By the way, thank you for your service!
I will take the 7 grill, send me a PayPal account and I will send you the money.
Graham
Thanks. Parts sold. To Ship on Fri.
Grill and heater.Michael
Oil Cooler and Fuel Level Tony
Rear View Scott
Willwood Whittle
Please email me at Bonjo2 at gmail dot com. I cannot access the boards at work.
Last call.
New Prices.
$265 plus shipping (about 20) takes all. ($504 value). 24-006 - ACCUSUMP 3QT NO VALVE (24-006 $249) New, test fit, still factory air charge w/manual valve
+. # 24-270 - ACCUSUMP ELECTRIC VALVE KIT (24-270 $189)
T-fitting + check valve + Mounting clamps included
$85 Differential Cover High capcity w/brace adn fill/drain plugs. Trick Flow Specialties TFS-8510400 GM 10-Bolt 7.5/7.625 ($143)
$40 Hyundai radiator Locost, Brunton Stalker, Westfield, Caterham used, approx 15 miles.
$250. Birkin Rear wings/fenders. New. Primer finish. Never fitted. Drivers side has recess for muffler. Local only.
