jeffs Posted March 26, 2013 Share Posted March 26, 2013 Does anyone here have any experience with the r500 stack dash? I called Stack and they said that it was a custom kit and they have no information on it, and nothing was included with the car. I'm trying to set the alarms for the oil/water temp, and oil pressure as well as turn off the gear indicator since its not connected to anything (and is just a random number generator at this point). Has anyone programmed these settings, or hooked up the data logger? Link to comment Share on other sites More sharing options...
MightyMike Posted March 27, 2013 Share Posted March 27, 2013 (edited) I installed a stack ST8130 dash into my old Birkin. It's similar to the dash in the R500, but not as high-end. Installation was rather straight forward; however, calibrating the speedo and fuel level sensors took some time. http://i47.tinypic.com/o60m0h.jpg Edited March 27, 2013 by MightyMike added photo Link to comment Share on other sites More sharing options...
Croc Posted March 27, 2013 Share Posted March 27, 2013 Hi Jeff - Caterham USA should give you that information. It is a pre-programmed setup that is not fully configurable like the standard Stack dash. I found what I recall - this may help: http://regins.dk/dashboard_stack.pdf Here is the Stack manual page - may help: http://www.stackltd.com/support3.html Also look at these Blatchat postings http://www.blatchat.com/t.asp?id=174671 http://www.blatchat.com/t.asp?id=163764 Also pages 8 to 10 of the Caterham owners manual has a discussion on configuring alarms. The lap timer needs a beacon installed to work but that will only work on race days because you need a sender unit at the start finish line: http://caterham.co.uk/assets/html/technical/download.html Link to comment Share on other sites More sharing options...
jeffs Posted March 27, 2013 Author Share Posted March 27, 2013 Thanks guys. I think that answered my question (though I have to admit I don't like the answer). The r500 appears to be like an 8130 with parental controls on it. It seems odd that Caterham doesn't have a way of hiding the gear indicator in their display, especially when it really only displays the mood of the dash. Mine usually feels like a 5, but not always. Link to comment Share on other sites More sharing options...
