xcarguy Posted April 15, 2013 Share Posted April 15, 2013 (edited) Saturday, April 13th, HPDE at MSR Cresson (1.7mi, CW) with Apex Driving Academy. Shot with a Replay XD1080. Car specs: Engine—LS6 V8 with headers, cold air intake and mid tune (425hp/370/rwhp and 360rwtq) Transmission—Tremec TKO 600 with .82 5th gear; built by Liberty Performance (face-plating on 2nd,3rd and 4th gears and a host of other internal mods) Rear end—straight axle; Moser axles; Torsen LSD with 3.23:1 ratio Wheels: aluminum 15” x 10” with 4.5” backspacing (-25mm offset) Tires—Avon 10.7 x 21.5 x 15 (A11 compound) Shocks—Gaz adjustable Springs, front—600lb Springs, rear—300lb Brakes, front—Wilwood disc (rotors slotted and cross-drilled with BP-10 pads) Brakes, rear—Pontiac Grand Am GT rear disc (rotors slotted and cross-drilled with stock GM pads), mated to the rear end via Brunton Automotive brackets Edited May 19, 2013 by xcarguy added video Link to comment Share on other sites More sharing options...
WestTexasS2K Posted April 15, 2013 Share Posted April 15, 2013 MSR is a fun track. Plenty of runoff area and nothing to hit close to the track if you go off. I like the CCW better but its fun either way. Looks like the car ran good. Having seen John Meyers Stalker run there is no need to convince me of the performance capacity of a V8 7. Hopefully I will get to meet you up there sometime. Link to comment Share on other sites More sharing options...
