Nice! The Caterhams seem to have a hp advantage and the X-bow a braking advantage w/cornering abt the same? What spec engine in the X-bow and approx power of your 2.3 Cosworth?
You must keep in the mind the effect of the aero package the KTM has over the Caterham. It is a night and day difference that is more apparent than normally mentioned.
MvP
I am now in Spain for the dealer meeting and testing the new R 485!
I will post some racing videos soon.
X-Bow, Slicks and 360 BHP. The reason for braking and performance is the good aero of the X-Bow.
My 2.3: 280 BHP Cosworth, SADEV with paddleshift, Nitron 1-way, 8"+10" BBS on Formula Renault Slicks, +40mm wider rear wings.
It seems odd that with better aero and an extra 100 hp the X-Bow is slower on the straights?
Look forward to the R485 posting, 1st I have heard of it. Does 485 reference its weight in kilos?
Edited by Kitcat
The X Bow is 1700lbs dry before driver and fuel. My CSR is 1270lbs dry. 100hp is not a lot to deal with the extra weight penalty. Also aero does slow top speed slightly.
The 485 is probably hp per ton if it is following the past R500 nomenclature?
