S1Steve Posted June 8, 2013 Posted June 8, 2013 Dave D and I are working on a few projects together . One of the things we would like to do is install a aeroscreen in place of the windshield. Superformance doesn't make aeroscreens for the S1. So I need some dimensions from anyone that has one installed on their 7, so we can see if we can make something work on the S1. The main issue would be over all length side to side. Thanks, Steve
Croc Posted June 9, 2013 Posted June 9, 2013 I can take measurements of mine this week but I am confused (easily done I know:dupe:).... Won't the overall width be dictated by the width of an S1 and the attachment points on the side of the scuttle? So I would have thought you would be needing more the angle of elevation and depth from scuttle to top?
S1Steve Posted June 9, 2013 Author Posted June 9, 2013 I can take measurements of mine this week but I am confused (easily done I know:dupe:).... Won't the overall width be dictated by the width of an S1 and the attachment points on the side of the scuttle? So I would have thought you would be needing more the angle of elevation and depth from scuttle to top? Your correct, but I have to start somewhere.Just trying to see if the width of your cowl on your CRS is even close to the S1. The curve of the cowl may be different, lots of things may not be even close. And by now, that's what I expect.... Attachments can be made if some type of aeroscreen fits fairly close . Thanks Mike....
