jfgw Posted April 20, 2006 Posted April 20, 2006 I am interested in doing some trackdays at my local track, Mid-Ohio. Does anyone know the easiest way of doing this, for example joining a club for test days, or is there an organization that specializes in track days for enthusiastic drivers? Thanks
slngsht Posted April 20, 2006 Posted April 20, 2006 Can't help you with Mid-Ohio track days, but dropping in to say welcome aboard . Our local track has Fridays at the Track >http://www.bsr-inc.com/FATT.HTM. I guess one thing to look into if it's not a SCCA event or something similar is insurance - if you're worried about that.
jfgw Posted April 21, 2006 Author Posted April 21, 2006 Thanks slngsht, that's exactly what I was looking for. I will post again once I find out, incase any of the East Coast guys would like to join me.
cadillacjr Posted April 27, 2006 Posted April 27, 2006 Mid Ohio is also my local track(90 miles away). Just did last weekend there with NASA OH/IN. They have racing but also HPDE (high performance driver ed) separated into 4 different classes for novice through advanced drivers. There are 2 more NASA events at Mid Ohio in July and August plus the Nationals in September.
jfgw Posted April 30, 2006 Author Posted April 30, 2006 Thanks Brian, Could you please point me in the right direction for the requirements for the NASA events? I would love to take part, but am new to the procedures in the US having only been here for a few years from the UK? Many thanks,James
cadillacjr Posted May 2, 2006 Posted May 2, 2006 There is a lot of info at www.nasaproracing.com and you should check it out. The short version is that once you get a membership($40) all you need is a mechanically sound car and sa2000 or better rated helmet(no motorcycle helmets). The pre-tech is something you do yourself using a form from nasa, nothing too technical just belts, hoses, lug nuts etc. followed by a quick once over by the tech guys at the track. The cost for an event seems to run about $150 a day, this gets you 4 20 minute track sessions. If you've never run with NASA before they start you in HPDE1(novice) where you are assigned an instructor to ride with you. I don't know your experince level but if you are just getting started this is a great place to learn and if you are more experienced your instructor will confirm this and sign you off for a more advanced run group. I hope you come out, it's always great to see another se7en at the track.
jfgw Posted May 17, 2006 Author Posted May 17, 2006 Brian, That's great info - thanks very much. I certainly intend to get to Mid-Ohio for the August event. The delay in replying was while I actually completed the purchase of the se7en. I now have it, have successfully negotiated the hoop-jumping of registration in Ohio and the car is on the road. This is a Chris (from sevens and elans) built car running a QED Vauxhall lump with various nice bits on it, including his Spa mirror set-up. I can certainly recommend his workmanship. I look forward to seeing you at the track, and if you ever fancy a 'blat' locally, I am based in Powell, Ohio and would enjoy an early morning run to Hocking Hills one weekend. James
slngsht Posted May 17, 2006 Posted May 17, 2006 jfgw, now that you have the new ride, post up some pics
jfgw Posted May 17, 2006 Author Posted May 17, 2006 slngsht, probably the simplest way of seeing the pics is to go here - > http://www.kodakgallery.com/Slideshow.jsp?mode=fromshare& ;Uc=jj0zmgt.7glemuhd&Uy=-2xwue1&Ux=0 Now starts the list of upgrades, starting with that gear knob!
