iceberg1234
Everything posted by iceberg1234
  1. Not sure where you're located, but in upstate NY these guys do outstanding work for a reasonable price. http://www.berg-racing.com
  2. I used Bear Transport to get my Birkin from the State of Washington to NJ. Arrived safe and Clean for under $2K
  3. I recently purchased new ball joints from Dick at Texas Motorworks. The pair, including the threaded adjusters cost about $50 and came in a few days. Much simpler than finding a "comparable" part.
  4. Gherkin, This looks awsome! I have the same engine/sump on my Birkin. Do you think your friend would want to make another one? I have the stock aluminum guard, but it seems fragile. Paul
  5. On YouTube:
  6. I used Bears Transport to get my Birkin from WA to NJ. They were quick, professional and offered one of the better prices. 847-810-7641.
  7. UPS will also hit you for duty. Often in a bill that comes later. Not a high percentage, but enough you notice if you're getting big ticket items.
  8. Thanks, Tom. That's only about 90 minutes from here, so is do-able. I'll give them a call. Yep, 7 gatherings at NJMP are in the plans......
  9. So, I want to replace the stock bar on my '03 Birkin with something more protective for track days (a roll cage). I see a couple of options: Buy the cage sold by Texas Motor Works, or find a local shop to fabricate one. The one from TMW has the advantage of being bolt in (and can be swapped out for stock easily) but is a bit pricey, especially with shipping to central NJ. A custom bar needs be designed and I need to find a shop nearby that is competent in both design and safe fabrication (and could also get pricey). Comments, advice, random thoughts?
  10. Can't find the photos?????
  11. Croc, thanks, I posted there per your suggestion. Pi7ot, I assume I just check the resistance cold and hot? Are there some standard numbers I should be looking for, or are they specific to the sending unit? Thanks
  12. Anyone have any experience with a Zetec 2.0 and a GEMS ECU. The car I just bought has this setup, but is way out of whack. It runs, but is so rich it burns my eyes. I have the gear to tweak the ECU, but wondered if anyone has a decent map I can start with. I'd rather not have to build one from scratch. Thanks
  13. I couldn't get a cheap switch from O'Reillys as mine has a steering column lock. So I took the lock off and went back to the locksmith. The blank for the ignition is from an old Datsun (Ilco DA25-P) and the gas cap is from an older Honda (Ilco X252 HD108)
  14. Anyone know what key blanks a Birkin built in 2003 would use? I want to make a second ignition and gas cap key but Dick Brink is out of blanks and the local locksmith is stumped. Thanks
  15. FYI- I just bought this car..........the adventure begins.....
  16. OK, as some of you know, I'm shopping. At the risk of opening a very old (and potentially contentious topic), this car has a solid rear. Is an IRS worth waiting for?
  17. This car was on eBay recently and didn't sell (or hit the reserve) at $22,730
  18. Thanks to you guys that braved the cold and showed up at the BCX meet. Enjoyed seeing the Superformance and Ultralite!
  19. See you then!
  20. Looks like BCX has a meet this coming Saturday. Any chance there'll be any 7's there?
  21. Yep, that's when I meant.....
  22. Yep, that's when I meant.....
  23. Birkin builder told me he's had the car listed for $48.5K and the reserve on the auction is less than that.
  24. I do plan to come to the members day next weekend at NJMP to get a look at your cars. Doylestown is also not a huge trip for me. What's "cars and coffee"?
  25. Oops, sorry, I know who makes the Stalker.....
