TurboWood
    South Bay, CA
  • Interests
    Things I can drive and engines
  • Occupation
    Engineer
  1. I’m glad you enjoy where you live. I would suggest you talk with a tax professional about this because everything I can find suggests Kansas operates the same as CA. Namely, that you do owe use tax to your tax authority for any item purchased out of state where sales taxes were not collected (or less was collected) by the seller. There could easily be exceptions or I could have bad information, but that’s what I find. Daniel
  2. I wonder if Kansas is simply assuming that all the parts would be taxed already and thus no need to managed by the DMV. CA does the opposite. They assume you have not paid and charge you accordingly (unless you have paperwork showing taxes paid). It doesn’t change that Kansas is expecting you to pay sales tax on all the parts. FWIW, a quick search suggests Kansas does have a “use tax” for things bought out of state that is equivalent to the total of stat and local tax at the location of delivery/use. If true, they would expect their pound of flesh the same as CA (albeit probably a smaller pound). Daniel
  3. Interesting, there aren’t sales tax on cars in your state? I also paid $6k (CA), but that was almost entirely sales tax that was not collected by the seller as they operated outside CA. I would have thought every state would charge sales tax. Daniel
  4. Grundy also rejected to quote in CA. Daniel
  5. Thought I would share that Hagerty won't touch Caterham in CA. At least that is what I was told by their sales person. American Collectors rates also doubled since last year. Daniel
  6. Well, the feedback is that they don’t think they will fit the Caterham chassis. He thinks there is enough of a difference between the two, with the Caterham “door” being longer. So, any other ideas? He sounded open to making a new mold, but needs donor parts to play with. Daniel
  7. I finally installed the air inlet duct I bought too long ago. Apparently a baby boy was the motivation I needed. Also, since my last update I did some more tuning on the engine and was able to resolve a few things that were bothering me. The idle never seemed to follow the tables, but was good enough to not be a big problem. However, the one really annoying thing that came with it was a crazy high (3-4k) cold start idle. It turns out I was using an AT calibration that caused both issues. Daniel
  8. Thanks guys. I reached out to them to see if they had ever tried fitting them to a Caterham. I’ll report back what I find. Daniel
  9. Hi, I am starting to think seriously about half doors and was looking at the options. Lately I’ve been driving with the full doors in place which is nice, but does remove some of the experience. What I’m concerned about with half doors is that they are all held in with snaps which seems like it would make getting in or out much more trouble. So, is there an obvious reason I couldn’t just cut the standard door such that I retain the hinge and “locking” mechanisms? I assume some stitching would be needed to close the cut, but is there something else I’m missing? Daniel
  10. I just want to point out that Croc (and community) have kept this thread going for over 10yrs now with over 1 post/day on average. That is impressive. Daniel
  11. Hi, I’m not sure how widely this applies, but I figured I would share. Ever since building my CSR I found the pedal spacing to be terrible. I could barely fit my shoe between clutch and brake, and this made heal/toe impossible. Frankly I don’t understand why Caterham would do this. My best guess is there is some regulation somewhere about the distance between brake and throttle pedals, but how could that apply to a kit? Anyway, my solution was to bend the brake pedal back to nearly straight. I believe Caterham sells straight pedals, but it was easier to source a factor pedal and bend it. I took my first drive with this over the weekend and it is definitely better. I’ll need some more time to perfect my shifting, but at least my right foot can finally reach both pedals. Daniel
  12. Balance is important, but don’t forget about the polar moment of inertia. The battery in the engine bay is behind the front axle. In the trunk the battery would be behind the rear axle. I think that will make the car slower to change direction. Daniel
  13. Thanks for the reply. Your comments match what I’ve read. The A052 warms up faster and wears more. I think this will work well for me because the rears were wearing about twice as fast as the fronts with the CR500’s. From what I’ve read the tread wear ratings are totally uncontrolled and basically at the discretion of the manufacturer. That is not a great system and I believe the CR500’s were rated as 20 which was the default for not rated. So, I figure the only way to know is to try. Daniel
  14. Coming back to this as I finally changed the tires. I decided to try tires that are more widely available than Avons. Details below. The negative of this is I did have to use different front and rear compounds, but I don’t think it’s crazy. My wear rates on the rear are clearly higher than the front and the front tire I chose should be a little softer. The other change from the CR500’s was front tire size. I think this change was also true for Avon ZZS/R options. I was happily surprised that the bigger tire fit without modification to the fenders (albeit it’s close). I took my first blat around the canyons over the weekend and first impressions are positive. For sure the new rubber is doing a better job than worn out old CR500’s. That said, I wasn’t able to induce understeer (thankfully). The balance was quite neutral, but I did over cook a corner a bit and was braking more aggressively into the corner than I would have like. This did cause some rotation on the rear, but it was very manageable. So far so good, only thing left to do is put more miles on them! -245/40/15 bfg rival s1.5 -195/50/15 Yokohama a052 Daniel
  15. Bringing to the top so Mike has to update us :)! Daniel
