bball7754
    St. Louis, MO
    Caterham
  1. My experience with TFL at Spa was outstanding. And the track is amazing. It was a total financial splurge for my 70th, as I didn’t share the Seven. But with the open track time (no groups), it would become much less painful if the Seven was shared among 2 or 3 drivers. And you would still get plenty of track time. I’m ready to go back! Steve
  2. Thought the passing of Chris Rea should be noted here on USA7s. https://en.wikipedia.org/wiki/Auberge_(album) https://www.motorsportmagazine.com/articles/obituaries/chris-rea-the-racing-fanatic-who-recreated-ferraris-legendary-sharknose/
  3. Just saw this thread. I posted about my trailer in the “other” trailer thread, but happy to provide same (or more) info here. I’ve had a clamshell Montrose trailer for about 10 years now. I originally purchased it for my Seven, but it’s also used for my Mallock. It’s aluminum, and I think weighs around 1,400 lbs. I originally towed it with a Volvo XC60, which had an official capacity of 3,000 lbs. It had a tow package, but not wired for a brake controller. I opted for the Tekonsha wireless brake controller, which has worked well. The trailer is extremely stable, unbothered by cross-winds. Other than acceleration and braking, not really aware it’s back there. I now tow it with a Jeep Grand Cherokee with the tow package, still using the Tekonsha controller. Jeep has a 5,000 lbs tow capacity. Steve
  4. First time in about 4 years this doesn’t conflict with a race weekend. Penciled in! Steve
  5. Yes, I do. Coming up on 10 years, I think, that I’ve owned it. Built by Montrose Trailers in Michigan. Weighs around 1800 lbs. Originally towed with a Volvo XC60, and now by a Jeep Grand Cherokee. Originally purchased for my Seven, but the Mallock fits just as well. Steve
  6. Craig - old listing, and it’s an entire engine, but just came across this:
  7. I have the Schroth 6 point for me, and ASM for the passenger. Consider it the best of both worlds, as passengers (not that I have that many) can be mystified by a 6 point. At on point (sometime in the 90’s) Caterham had two tabs behind the seat that could be used for the sub straps. My 1998 does not have them, so ended up doubling the sub and lap belts. And I also just sit on the sub straps.
  8. Mas du Clos looks beautiful! Like a track in the middle of a manicured park.
  9. Looks like (as usual) a great time! The last 3-4 years the date for this event has conflicted with a race weekend for me. Hoping that my schedule aligns next year, and I can make the haul to NJ! Steve
  10. I use the SFI dual durometer on my Caterham when I track it. With my helmet on, the headrest pushes my head forward awkwardly. So, I remove the headrest and attach the foam with zip ties. No foam when not on the track.
  11. TBH, this is my first foray into doing my own alignment, so I have no comparison product or experience. But once I figured out how to arrange it on the Mallock, I thought it worked well. With the live axle, I only had to align the front. I used two garbage bags under the front tires to make the adjustments easy, and that also worked well. It’s made for 3/4” pipe, but I went cheap and used 1/2”, which I’d read also worked fine. And it did, although I may yet “upgrade” to 3/4”. Not a huge investment, and overall I’m pleased and satisfied.
  12. I purchased this kit a few months ago, and just used it to do an alignment on my Mallock. A bit fiddly, and I had to get a bit creative to hang it on the Mallock, but it worked. https://calipergarage.com
  13. Burton Power lists two. https://www.burtonpower.com/steel-crank-77-65mm-x-f-rwd-std-journal-en40b-6-bolt-fp324w-77-65.html https://www.burtonpower.com/steel-crank-77-65mm-x-flow-rwd-narrow-jour-en40b-12-bolt-arrowc139.html
  14. Agree with John. I have Schroth 6 point drivers side, and the ASM for the passenger. They both are pull-up for the lap belts.
