Yes, it’s true. I am putting up “Bessie” for sale. Some changes in priorities — plus the fact that I just don’t use it enough.
As one of the founding members of the USA7s club, I’m a known entity and so is this car (my second Seven, btw).
That said, if you’re looking for an all-original car, this isn’t it. It was a “bitsa” when I first bought into it as a rebuild project and it continues to be. It is a well-finished and strong-running car that’s been well sorted out over my 10 years of ownership. Think of it as a vintage-looking (and driving) car that's had some very nice upgrades to make it safer/more reliable/higher-performing.
Car is currently garaged in Bucks County, PA. Can take/supply more pics and info on request.
A few more notes:
- Car carries build plate SB1341
- RHD
- Under total 4000 miles since restoration/rebuild
- Was restored/rebuilt by RMSCI/Caterham USA between 2010 and 2013, including a replacement “long front” chassis from Caterham, and complete reskin
- Was Ali/Yellow from factory, repainted in “Ford Black” with Colorado Orange noseband and wheels
- Runs magnesium “Wobbly Web” wheels that are vintage repro from Lee Chapman Racing — note that I sold the newer Dave Bean-sourced spare I had as a fellow Sevener needed one and I never liked that it didn’t totally match the other four wheels (only really noticeable if you closely examined back of wheel). If I was keeping the car, I’d get a steel Triumph wheel and paint it Colorado Orange for a spare.
- Car has Avon CR6zz tires (including one for a spare wheel)
- Originally equipped with a 1340 Cosworth Pre-Crossflow engine…now with a 1500 Pre-Crossflow (using original dual Weber DCOE 40s) dry-sump motor rebuilt by Savannah Race Engineering (Ted Wenz) in 2016. According to an email from Ted, engine dyno’d at 120.3 hp @ 6700 rpm/peak torque 110 ft lb @ 4900 rpm.
- 4-Speed Ford Transmission
- When the car was being rebuilt, we put in a Chris Beebe rear axle…I thought (and still think) his solution was the most elegant of the reinforced axles
- Front disk brake conversion in 2021 (using brackets from Canley Classics, UK and stainless calipers and slotted rotors from British Parts Northwest). I cannot overstate how much this change makes the car much more usable/safe.
- Newer (but correct) Spax shocks and springs
- Replacement 10-gallon fuel tank by Axminster Specialist Panels — note that this sits in a custom-made subframe so the original tank frame is intact
- Will come with vintage canvas top (it has side lights, so I’m assuming not original…I think they added those later in production) plus a newer vinyl top sourced from Redline
- Repro Elan 26R Steering Wheel from R. Dent (13")
- Recent replacement seat covers sourced from UK
- Repro Wingard tailamps (have originals/vintage units...which are hazy)
- Black/silver nose badge (as I felt the correct green/yellow would clash with black/orange paint scheme)
- Will come with two unpainted wider front fenders (front track got a bit wider after the disk brake conversion so front wheels extend past current fenders a little)
- Will come with custom car cover (for indoor use)
- Looked after by Exoticars USA (Frenchtown, NJ) and Ragtops & Roadsters (Perkasie, PA)
- Car just out of service that included rebuild of rear axle/brakes
POA. Not interested in trades.
