s2europa
Seattle
s2europa started following GEMS MDSL2 Info Wanted , Race car prep shop closing , Caterham S3 Steel Fuel Tank (Used) and 7 others
Carl, Can you find out information on the Europas? Thanks, Dan
Jon, where did you get the aluminum tank?
Thank you. This is great. I'll cut out some cardboard versions and try it out.
Recently acquired a 1964 Seven S2 race car that came with vintage type racing seats. I do not fit in the seats and would like to reinstall the stock bench seats (which will allow me to fit down in the car), which the car did not come with. Does anyone have the dimensions for the seat back and seat bottoms plywood blanks? I am planning to buy the bench seat vinyl kit from Redline Components and want to make sure I have the correct size pieces. Thanks.
s2europa replied to Croc's topic in Cars For Sale
There is a beautiful Caterham up for auction on Cars and Bids. Like new all around. No association. https://carsandbids.com/auctions/3vYkXyLj/2020-caterham-super-seven -
Elans and Europas steel wheels were indeed 4x3.75, but the wheel width is only 4.5".
A Pinto 2.0l with the FOG (Ford of Germany) gearbox will work, or there are plenty of vendors in the UK that have them.
Not sure if this car has already been posted... 1962 Seven race car https://www.ebay.com/itm/355538936946 -
That is a standard cam cover (other than the mods). There were three different cam covers. The early one with "Lotus" down the sides, this one (middle years) with Lotus over the chain cover, and later, the big valve cam cover that is ribbed down the sides and says "Lotus Big Valve" on the chain cover.
Now sold, thank you. One set of original Minilite wheels in 13 x 6 size. Lug nuts included, 3/8"-24 thread. $800 plus shipping from 98032, or local pick up welcomed.
Looks like the BIN went away with the bidding. Currently at $8800. -
Does anyone know how much the S4 Seven was selling for in Louisville? The ad is now removed. Thanks. Lotus Super Seven - cars & trucks - by owner - vehicle automotive sale (craigslist.org) -
Many years ago I purchased a GEMS model MDLS2 (ignition only) with dual 40 DCOE carbs for standard black top Zetec as a Caterham cast-off. I am just now getting around to looking at it and thinking about where I want to install it. I looked at the GEMS website and found one document for the connections. It looks like it needs a hall effect distributor, but knowing that the Zetec has a 36-1 flywheel and crank sensor and no distributor, I wonder if if it used the stock Ford sensor. I have no idea how it was set up originally on the Caterham. So I am looking for help. Googling on this system comes up pretty much empty handed, so I was hoping anyone with a unit like this still on their car, or with wiring/connection diagrams could help me out with how is it connected. GEMS makes it difficult to see the curves or to do any re-programming unless you buy their £200 dongle for the software, and that doesn't make sense to me when I can buy a new Megajolt ignition only system for $200. Thanks in advance. Dan
That same Seven S4 just sold a few weeks ago on ebay for $15,101. I wish them luck. https://www.ebay.com/itm/1973-Lotus-Super-Seven-/283755452973?hash=item4211249a2d%3Ag%3AZKcAAOSwT6leHeTO&nma=true&si=4vggvtunW%252FDxj5DwOSYCZRzzdvs%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
