MRH
    Boston
    61 Lotus
  1. What are to best red LED 1157 bulbs with a built in ballast resistor for older cars (1961) to have brighter brake and turn signals?
  2. @joe7 Can you please post a pic of the remote shifter you have?
  3. I occasionally get stuck in 2nd and need to open the transmission and break loose the center selector rod. This is annoying, but easy to fix. Then its good for a few weeks. Could this be the same issue? 61 S2 7, not sure which ford transmission I have STANCART 1 st gear has syncro
  4. Thanks. Oil is 20w50 Driven Racing Oil GP-1 (recommended by Ivey), trans is redline, will get the gear oil next.
  5. What is reccomended for a 61 S2 differential? New to the car and changing all the fluids.
