Everything posted by CarYenta
2025 Caterham 620R fully loaded. Just landed with practically no miles
CarYenta replied to Deman USA's topic in Cars For Sale
Dont get me started on my mountain bike's value Jest aside, I was hoping for a better BaT result. You certainly have a bunch of great photos to go off of now, I think that should expedite a sale. Should probably put a price in the ad for folks to counter on? -
Once again, Pickles to the rescue! I've spent probably 16+ hours trying to get the intake manifold to intercooler pipe installed without pinching the thermostat coolant tube too much. Turns out I didn't read Pickle's other article well enough which had the answer right in it. So for others like myself - zip tie the darned coolant pipe to the supercharger outlet pipe, and place the aluminum tube on top of it not under nor on the side. I had to loosen all my upstream barb fitting to get enough slack but then it was very simple to do so: Note that the supercharger to air filter tube is out to do this. Fix the elbow to the tube, with your O clasps readied but not tight With the intercooler either locked down or loose, you can put the pipe right into it first and slide the other end right in from the side: Now, with liberal use of silicone spray on both ends of the elbow and the intercooler connection, pivot the tube and elbow clockwise (up) towards the butterfly valve and get one side of the lip over the edge, making sure to remember the large O clasp: Now, pivot pivot pivot. Takes some convincing, so more silicone spray the easier it is: Fiddle around twisting the tube a little, the elbow a little, and it will pop right on. I had previously added so much silicone spray from prior methods that I had to hold the elbow in place to prevent it from sliding a bit while tightening. Done! Look at all those bottle scars.
Exhaust is on. Pro tip, the rubber pieces for the exhaust hangers go on top, not on bottom of the mounts 😂 Exhaust was on, hanging waaayyy down, doh! If I were to do it again, I'd try bolting on the exhaust hangers, connecting the rear silencer and connector pipe together, then sliding in the hangers while attaching to the side pipe. I see why people complain about scraping these, even with the hangers on top of the rails, it's pretty low. Anyone know how loud it is if you just modify the side pipe exit to stick outwards? I believe the cat is in the side pipe,band no cat in the rear silencer, right?
Another pro tip from Pickles, I had my intake side engine mount spacers on the exterior of the mount, acting like washers and not as spacers. I moved them in between the engine block and mount hoping it would give more transmission clearance. Loosened all parts, engine on jack, didn't really move much, hard to tell. Wow, the 4 into 1 exhaust springs really were a pain! Much much struggle but got these on. My kit was missing the 4x m10x20 mm differential to driveshaft bolts as well as the throttle body to intercooler exit "reducing elbow for intercooler". The fit is going to be extremely tight, I'm concerned! I can wiggle the intercooler around to install, but these photos are with the intercooler exit pipe jammed as far is as possible into the intercooler and the intercooler bolt aligned. I will finish the exhaust, tidy up a bunch of wiring with rivnuts, start putting in the fluids, and hook up the shifter while I wait for the elbow and diff bolts to show up. 🎉
It has been an incredibly busy summer! Since I'm too short for the stock shoulder belts (metal strap hits the top of my shoulder with the seat scooter forward), I installed some Schroth Flexi 2x2's. For the sub belts, I had to source my own hardware. From Grainger, I ordered four 7/16-14 x 3 in hex head bolts (not the most aero, but whatever) that are inserted in from underneath the floor pan (drill new holes) into a bolt-in harness bracket, into a thick walled 7/16" hole by 1-1/2" long spacer (https://www.grainger.com/product/Spacer-For-7-16-in-Screw-Size-4GVD9), then through the pre-existing sub mount tabs, and then a washer and 7/16-14 nylon nuts. Interestingly, the bolt in brackets on the passenger side, which has fixed rails, interferes with the bolt in harness brackets. I also tried putting the harness brackets above the spacer instead of below, but it would interfere with the seat back instead. I then elongated holes in the floor to get it to fit. I measured wrong! AHHH. I ended up flipping the seat rails 180 degrees from the picture shown to get it to fit and mounted in the original holes. This means, however, that the passenger seat is scooted quite a bit forward instead of slammed back against the back wall. I will need to search for some aftermarket seats rails. I also bought some 40 mm wide nylon washers to cover up the elongated portion of the holes as they were now wider than the stock aero washers (https://www.amazon.com/gp/aw/d/B0DHH73CC3?psc=1&ref=ppx_pop_mob_b_asin_title). Finally, I raised the driver's seat up slightly using Tillet brand nylon seat spacers. They seem near identical to the cheap Amazon ones, but do come in thicker sizing. I also got some longer M8-55 mm hex bolts to attach the sliding seat rail to the seat since the stock ones (M8-40 mm I think?) no longer poked through the washer stack at all. There is considerable thread in the seat, so could have gotten longer ones even, maybe M8-70 mm or so. I added height of an additional three of the 40mm OD washers x 4mm thick for a whopping half inch height increase. I can see so much now. Also, I attached all the coolant hoses and supercharger piping finally. In another thread, Pickles kindly layed out how to get around multiple issues which made my life considerably easier and with -1 broken knuckles. Thanks! Fascinatingly, and perhaps unsurprisingly for Caterham, my builder had dibs on the ruler that day and cut my coolant hoses to the correct length from the get-go, so I had no trouble fitting the lower radiator hose with no interference from the supercharger exit pipe. Next up are manifolds woohoo 🎉
Good to know! I assume at some point the heat shielding will wear away at the contact point, but I can deal with that if/when it happens.
That is the plan, if it works, I do not know haha. I think I'll be using a breaker bar and a wedge to get it straight. One more thing to do, my seat when the slider is all the way forward is still to far from the pedals for me. I'm thinking of making a new set of floor pan holes a few inches forward of the existing holes with a step drill bit. Any problems doing that? I'm going to bend the seat slider adjustment rod 90 degrees so it doesn't hit the footwell cross member.
Thanks for the links! My kit has the transmission mount spacer which I used. It sounds like if I can't move the left side of the transmission in the tunnel away for more clearance, I should only worry about it if the transmission is up against a hard thing/rail and not so much if it's against the padding?
Thanks for the tips! I'm here to learn, not for praise so no worries. The blue painters tape ripped 😂 so I added a few extra layers. Managed to not actually scrape it however. I raised the front of the car up as suggested and that definitely helped in getting the propshaft lined up as well. The top tunnel gaitor I didn't realize was elastic, so it made it over the hand brake no problem, silly me. Had to remove 6 carefully placed zip ties to unplug the heated seat connectors :/ I put a pan under the transmission plug and drained the fluid as recommended, worked great. Except then I had to remove the engine again to change the chain lengths, plugged the hole, put engine back into the car at a large tilt, and unplugged it expecting no fluid to come out. Suffice it to say, that was real dumb! Poured out all over me. Alas, engine is in! Engine mounts on, transmission mounts not quite all the way on. I'm going to install one of the 4 carrier bolts upside down (nut inside the car) as there's two or three extremely stiff wires blocking the bolt from coming in through the top. I guess people in England have to worry about MOT inspection but not I. I had to take off in total: the intake manifold, radiator, intercooler, oil cooler, super charger reservoir, supercharger, alternator, and two pulleys. Also, I was as close as I could get the hoist at one point, it was touching the sway bar, so had to manually push to swing the engine over the upper cross members. I'd recommend anyone thinking of the smaller harbor freight 1 ton hoist to get one with a longer reach. The transmission is a little skewed and is touching the tunnel on the left side. I plan to play around with a pry bar while tightening to see if I can get it centered better. Here's going in before removing the upper left alternator and just below black pulley, with a jack under the transmission to help level it with the propshaft: From underneath helping align with the prop shaft: My askew transmission: Engine in from top with a few things being reinstalled: And done for the day
Oh interesting, I will try again! Stock handle.
The issue is my hand brake handle appears to be glued on. There are no grub screws. I have to take that off?
Mated the transmission tonight, decided to give the engine-in a go. Quickly realized that indeed, the radiator and oil cooler needed to be removed or else the hoist can't move for enough back. Managed to jam the transmission into the bottom frame rails as the box-bars at the bottom are quite a bit narrower than higher up. Jacked up the rear so ji could guide it in better for a re-try. Thought it was going to make it, but the supercharger and mount are barely in the way. Giving up for tonight and have to take that off. I'm a little confused about: 1) when I pull the cap off the end of the transmission to mate the driveshaft, am I going to get a face full of transmission fluid?? 2) how to attach the two wires at the top of the transmission 3) how to remove the hand brake handle to pull off the center console trim 4) the two bolts at the very bottom of the transmission bell housing are not used, right? They were attached to the dry sump skid plate.
Noted - the feet are quite longer than where the engine hangs. If it feels tippy at all I'll move the top arm a few notches back.
Engine and transmission about to be mated. I managed to lift the engine out of the crate 180 degrees backwards, doh! Questions: Does the transmission spline and throw out bearing require any lubricant? Do I put locktite on pretty much everything? Or nothing? What is the engine mount torque of the main center bolt? Cheers!
Prepping engine bay. Removed intercooler and rotrex fluid can, engine mounts, moved some wiring and tubing around. Hoist getting prepped, car moved over a bit since my garage door opener motor was in the way Going to try to keep the radiator on.
Excellent! I really hope everything is smooth and easy.
Car is almost here! In the meantime, I can't find a single 620 S with a 5 speed engine/transmission install guide or build blog other than the official Caterham guide. Can someone point me in the right direction?
