fotsyr
Everything posted by fotsyr
Elan S1 mount from Bean or Rd.
I believe its a standard Caterham yellow. Only the rest of the car was painted a special colour, chosen by Mrs Jane Nearn. chris
St Augustine, FL
Replacing entire front end of Caterham and need some guidance
fotsyr replied to Jonathan Cort's topic in Build Threads
I did a similar repair about 25 years ago. Carefully pulled out the side skin, installed new front end and use the side skin as a jig. Used a chassis plate to ensure all even. -
Both of these parts are brand new, but were in an accident. The scuttle is missing the firewall. Easy to make a new one. The damage is in the RH corner and almost hidden by the windscreen. The bonnet has 2 areas of damage, on the RH side, as per the photos. The bonnet does not have any carb openings, just the rear intakes. Asking $200ea, OBO>
I have 1 from a Ford 1500, its the same.
I actually built Patrick McGoohan's Prisoner 7 and delivered it to him in Richmond, VA. His daughter and son in law lived there.
Sale pending to columbia caterham.
You should read the advert again carefully.
I owner Prisoner 7 for sale. 3800 miles, 1700cc xflow, 5 speed dedion, registered for use in all states.
Which means I may have sold it.
5 speed Caterham gearbox gear lever fits directly into the gearbox. Rods are not required.
This gear lever for the Escort sport gearbox has a plastic ball at its end. NLA. The plastic does deteriorate. You will need to modify the end of the gearlever to accept the gear knob. $135.00 + shipping
This is the second rod that should be fitted to the Escort sport gearlever remote. Most of the 7's fitted with this gearbox did not have this second rod fitted. Comes with the 2 top hat sleeves/bushings. Only 1 rod is availabe. This is the gearbox with the integral bellhousing. $50.00 + shipping.
You should make sure you can remove the rear hubs easily before you continue. I have standard used Triumph front huhs in stock, also new rear wheel cylinders and brake linings. I also have a copy of Tony Weals book for sale. PM.
The engine is back for sale again. FYI Uship is an easy cheap convenient way to ship this.
St Augustine FL. But its sold. What are you looking for, have more. chris
Ford 1500cc non crossflow 120E engine complete less exhaust, intake manifold and dip stick. Includes flywheel and clutch assembly. Engine turns by hand. Ex a Lotus 7 from CA.. Sump is unmarked. Mileage unknow. $500.
1 PR of Caterham Luke Red `4 pt belts, buckle will accept a crotch belt. With hardware. $250 + shipping.
This is a new unused standard RH front wishbone for either a Lotus or Caterham 7, upto about 1992. Its has been electroless nickel plated. New rear bushing fitted. $115 + shipping.
SOLD
Apparently he has been ill for some time
SOLD
