locostv8
VA Mtns
Interests
Hot Rods
Occupation
Retired to build Hot Rods
FYI Sears has a gun that develops just over 600 ftlb. My Corvair had a heating problem, in about 2 blocks the water temp was pegged. Inspection showed no bubbles in the radiator. I had to get a kit to test for exhaust gasses in radiator, it is a realy good idea if this used to lower the water level a bit. The fluid finally turned yellow the second time around. There was an almost imperceptible track between two cyls. New gaskets and a BIG radiator and it was my dd for 2 years with no further problems.
Given the miles while you are under the hood you might want to throw a timing chain on it and never put back an old water pump.
You need to use http://www.usa7s.com/aspnetforum/ This site seems much faster no time to play solitare.
Yes. I generaly play a game of Solitare waiting for loads.
That sounds like it was worth the trouble/cost.
Sometimes the balast is a resistor wire.
Another solution is a steering quickner available in 1,5:1 and 2:1. This is a case for using joints that are way over the needed specs, this is not an area to save weight on.
Now that there are a few miles on the car do you think the Lizard skin helped with temps?
Do you use the handbrake when sitting at a stop light?
locostv8 replied to solder_guy's topic in Off Topic
When I lived in San Francisco I had a 1.3L Alfa which didn't like the hills at slow speeds let alone being dumb enough to stop on one. The 7 L Dodge disn't care either way. -
Probably wouldn't take FTOD at autox but shure looks like fun.
locostv8(Jim) is in the hospital
locostv8 replied to Arya Ebrahimi's topic in General Sevens Discussion
Got out of hospital Mon late. I had one stent installed just after the attack which is the 4th in 12 years. Doing well but have to have another stent within a couple of months. Thanks for the kind wishes. Jim -
Hi from the hospital. Had a stent inserted and will sooon need another. Think this will slow things down a bit. Thanks for the wishes. They lied about the release date. -
I'm currently in the hospital due to a 4 th heart attack. Intervention nearly complete though will need a second cathretization soon. Think this will slow things down a bit for now. Jim
Rob Did you strip the paint on the fenders and other fiberglass? When stripping Mazda's fenders I found the rears had a HEAVY coat of what almost appeard to be clay, when it was all off the fenders semed to be about a third lighter there was no jell coat on rears. I will fix with light coat of jell coat then sand.
Drive home last night with out a clutch cable was
locostv8 replied to DB6's topic in General Sevens Discussion
Being frugal/cheap I would look to see if I gould braze a sleve over the broken piece which could be then brazed to the cable.
