Recently picked up a WCM Ultralite S2k. I have the manual, but had some questions.
The manual mentions Charlie using 2.5mm of rear toe OUT per side.
Rest of alignment was about -2.5 degrees of camber front, -2.2 degrees rear
Front toe was -.2mm per side
Other alignments I was able to dig up among forum members typically had a bit less camber front and rear often paired with slight toe in front and often 0 toe in the rear.
Never dealt with a 7, but often run 0 toe all around in a Miata used for autocross.
I am looking to autocross the car, but for right now I would like to tame a very nervous car(mainly over bumps). I am also looking to shim the tie rod end to level out the rack.
Shocks are the QA-1 with 500f/400r springs(I am told, but not sure).
Just looking for some direction on alignment.
