s2k7
Everything posted by s2k7
  1. xxx
  2. http://i62.tinypic.com/ae14i8.jpg Delete it or lost value on your car? WHAT DIFFERENCE DOES IT MAKE?
  3. Smidgen 7 !
  4. s2k7
    Wiring help
    So, when you turn the ignition switch to 2nd position, not a single accessories (light or any 12V attached to the system) is on? Totally no juice ? The 2nd position switch (ignition key) should be connected to the main in order to power up all your accessories, the ignition system, the cluster gauge and all. If you can poke under the steering and test the juice of the wire at the 2nd position switch, you can follow that wire all the way to the engine bay and troubleshoot from there. Usually the Brits uses big 12ga brown wire for +12V....U.S. usually use red wire. The 3rd position is for cranking the engine, No need to test the cranking wire if you don't get any juice at the 2nd ignition switch position.
  5. s2k7
    Wiring help
    This is not SVT engine but almost all starter has the same wiring: http://i60.tinypic.com/2eckdwl.jpg
  6. Westfield is big in Europe Classy setup !
  7. I assumed the OP also turbo? Yours pretty good power -- 265 torque is pretty good...does it hook up?
  8. How much power you projecting on that Miata turbo engine?
  9. Thank u
  10. "You may want to send slngsht and NVP66S" Good idea..he's in the build process. arigato !
  11. I need to replace my stud and I have a Westfield. Anyone here knows what is the stock wheel stud "Knurl" diameter size of a Westfield? I'm sure Caterham has the same stud diameter.
  12. I think you will get the same FIXED price you gave to the insurance company when you insured your KIT/Replica/composite.
  13. wow !!! that's the reason why - i only have 6 gallons. that means I need to peee & look for station every 80 miles. one reason why i don't go cruising and be a burden with the group
  14. ...of fuel in your tank? ......in the hi-way driving, how many miles do you get in the full tank? I'm sure depending on big is your engine, V8 could be less miles?
  15. s2k7
    Another kit coming
    ....but for me, i think a lot of money, I could get an EXIGE or Evora or Esprit on that money.....hey, but its very nice - some people will buy it.
  16. one Lotus elise is enough. I like the rear light though....must be nice for the 7 http://www.boldride.com/ride/2014/zenos-e10#gallery/5
  17. s2k7
    Easy loader
    https://www.facebook.com/photo.php?v=287077404799924
  18. ....that looks like the CN TOWER IN TORONTO?
  19. You have 8 valves right? Do you know the reading of each cylinder? If its mine, I will hone the cylinder and put a new ring too.
  20. Overtime as you rack the steering wheel, the hot (12v) wire breaks and touch the metal. Put a fuse on the hot wire....just to be safe.
  21. ....no one can suggest a fix without telling the symptom
  22. Maybe this Hardtop....
  23. ....ok, it's fugly
  24. Nice article to read: http://theweek.com/article/index/258275/which-american-state-is-most-like-crimea Oh, MY HEART WILL NOT BLEED to see WASHINGTON DC SECEDE :smilielol5:
  25. oh...we have answer for no sound at all -- here: Formula E DEBUT
