I've been Carbotech brake addict for quite a while both on & off the track. I tend to prefer the XP-8 compound for both street & track use unless you find that a more aggressive pad is essential. I also wouldn't bother with anything below the XP-8 compound. I tried a set of bobcats once, but managed to fade them in my Evo. I've lost count of the number of sets of XP-8 pads we've put through about half a dozen different track cars.
The XP-8s will squeak a bit at stop lights (although enough brake anti-squeal compound will keep that to a minimum), and when used aggressively on the track, will cook all the afore mentioned anti-squeal off the pads. Plan on re-gooping after every track day.
That said, they are the easiest to modulate brake pad I've ever driven. Great initial bite (both cold & hot), fantastic resistance to fade (as long as you don't tend to drag them), and they still work well even when they are worn thin and smoking as you pull off the track .. I've run one set down to about 1/8" thick on the front of my Evo at a track day. And they last a long time for a track oriented pad. Downside is cost; they are definitely not the cheapest brake option.
