papak Posted February 9, 2017 Share Posted February 9, 2017 (edited) I have finally resolved my wiring issues and everything works correctly on the Birkin. I installed the scuttle and nose today and realized that the oil filler neck on my Duratec 2.3 protrudes above the hood by nearly half an inch. GRRRR! Has anyone had any success in repositioning the filler neck to the lower side? I presume that the cam cover material is FRP? Can this be successfully epoxied? The alternative is either the cam cover Tom Carlin sells ($485), the Raceline one (similar price plus shipping from the U.K.) or the Caterham one. Are the Mazda covers even on both sides? Has anyone done this mod? TIA Edited February 9, 2017 by papak Link to comment Share on other sites More sharing options...
Davemk1 Posted February 9, 2017 Share Posted February 9, 2017 Is there a lower profile cap that you can fit? Lower motor mounts that can drop the whole lump down enough? dave Link to comment Share on other sites More sharing options...
vstryker Posted February 9, 2017 Share Posted February 9, 2017 Kevin, I took the original cap, shaved down the top part then epoxied a thin round aluminum plate with an allen head button. I use the allen head to easily twist open and close the filler cap. You can probably even use a counter sunk allen head too. It gave me that extra 0.5" to clear the bonnet. http://i25.photobucket.com/albums/c87/vstryker/20160721_15061301_zpsy6cyhz3q.jpg Link to comment Share on other sites More sharing options...
papak Posted February 9, 2017 Author Share Posted February 9, 2017 I did the same thing but on the Birkin, the motor mounts were designed for the 2.0l engine. The 2.3l sits about ½" higher in the chassis. The high point of the front part of the cover touches the nose and the riser on the oil filler would have to be shaved off and relocated to the low side at a minimum. Upon looking at it again today, I think I would do better to get the lower profile cam cover from Tom Carlin ($485). The cover offered by Raceline won't accommodate the individual coils. If I go this route, I'll try to modify the old cover as a separate project and post the results. Link to comment Share on other sites More sharing options...
vstryker Posted February 9, 2017 Share Posted February 9, 2017 I thought the Raceline would work on individual coils as I've in it on Chris's car here http://californiacaterhamclub.com/chat/attachment.php?attachmentid=1183&d=1362719374 I would get the raceline as it looks much better and costs about the same with the current exchange rates Link to comment Share on other sites More sharing options...
1turbofocus Posted February 22, 2017 Share Posted February 22, 2017 If you look around you can find some Aluminum valve covers ( rare ) and cut and weld them as needed Tom Link to comment Share on other sites More sharing options...
Alaskossie Posted February 27, 2017 Share Posted February 27, 2017 Another solution (not the least expensive, I'm afraid) is to go with the Duratec dry-sump system, and eliminate the filler cap entirely..... I bought a Reverie carbon-fiber valve cover, and had the filler hole deleted. The c-f cover looked great on the car, but would not seal tight against the head, and oil leaks resulted. i sent it back to Reverie to be checked and re-surfaced, and have not yet installed it. But this route does eliminate the filler hole and cap.... Link to comment Share on other sites More sharing options...
