BlakeJ Posted January 19, 2018 Posted January 19, 2018 My recently "finished" (never really done, is it?) 360R SV runs great the couple of times I've fired it up and driven around the block. Oddly, water temp & oil pressure gauges function fine. The tach only rises to about 1k RPM (it does move, but that's it). The Speedo doesn't move, though I have not yet tried a new sensor or the extra grounding wire. Anyone else have this experience or any suggestions?
xcarguy Posted January 20, 2018 Posted January 20, 2018 Some starting points: First and foremost - grounds? Tach - does the tach have a 'set switch' (for lack of a better term) on the back of the housing, i.e., 4,6,8 cyl settings? Fuel gauge - correct ohms range for the gauge (for example, mine is 0-90 ohms)? Speedo - assuming electric. VSS properly wired?
Sean Posted January 20, 2018 Posted January 20, 2018 This is a known Caterham-specific issue, and has been brought up on Blatchat before; when new, my car had the same issue. While it could be something else, this would be the first thing to check, and only takes a fraction of an hour to do: Up behind the knee trim panel on the right-hand side (passenger side in LHD car) is a threaded stud with a few grounds attached. From the factory, this stud can frequently have excess paint/powder coat reducing its effectiveness as a grounding point. To check/correct if this is the issue: remove knee trim panel locate stud loosen or remove nut on stud pull back or remove wire end terminals from stud remove excess paint/powder coat with knife, solvent, sandpaper, Scotch Brite, etc. re-install wires and nut verify gauge functionality has/has not been restored Replace knee trim panel, if desired.
BlakeJ Posted January 22, 2018 Author Posted January 22, 2018 Thanks for the suggestions. Will check grounds. Also noticed some loose wires from the factory near right rear of fuel tank, so perhaps fuel sender was not connected.
