  • Replies 62
Yep finally got the M-ride to find the M-Unit I set the aux 2 to engage as soon as the ignition energizes so that is solved as I now have an Aux fuse box very impressed at the customization option in the M-Unit.
The setup seem to be working with the inputs/outputs triggering with the wheel buttons.
Jeff: Under "Handlebar Controls" on the M-Ride did you set these up or are they just used for the M-Button?
Now the frightening task of rewiring the car.
Those are just for the M-Button. The M-Unit already expects the inputs to be momentary ground signals, so you just need pushbuttons. Or if you want the buttons on a removeable wheel then you can put something like the Cartek Wireless Steering Wheel in the middle. That also let me set my wiper controls to latch. That way I just push the steering wheel button and my wipers stay on. The button sends a signal to the Cartek receiver when then keeps that circuit closed (on) until I push the button again.
Now if only I could figure out what to do with my last button. I have one unused button on my wheel with no purpose. I already have automatic logging on the ECU and the AIM, so don't need a logging button. I have a low-rpm rev limit until the oil is hot, so don't need a "pit" button. Maybe I need to add a second horn that play "la cucaracha", but that would add weight...
  • 6 months later...
Thank you for checking this out. Very helpful. Have been searching for a small pdm for chassis and may have struck gold.
