Needs some help obtaining an old 3 rail "Bullet 2000E" shift lever assembly for a Mallock. Same as the original Elan trannys Actual lever shape not important. Any laying around out there? Thanks Chris D 3 rail Ford Shifter.jpg
Are you going to use this with the 3 bolt adapter at the end of the tailhousing (Integral Remote) or the 4 bolt adapter near the front of the tailhousing?
My experience is that this one will only work with the 4 bolt adapter setup.
Ray at rdent.com in the US and Steve at sjsportscars in the UK had them, at last check. Not cheap, though.
Here's a long shot that might be worth a try. There's a gentleman near me that has a bunch of Cortina parts. He pretty much runs adverts continuously on the local craigslist:
https://sandiego.craigslist.org/nsd/pts/d/vista-cortina-hub-caps/7097798961.html
I've purchased a number of items from him over the years for my various Cortina, Lotus and Seven projects. The last item I bought from him was a transmission main case a while back.
His name is Phil.
Correct. The 1/2 ball mounts directly to the top of the box cover with a round circular cone - not shown - but I need that too. The cone that supports the lever in place threads in the the ~ 4" x6" - 4 bolt, top cover.
thnaks, Cd
