Chris D Posted March 27, 2020 Posted March 27, 2020 Needs some help obtaining an old 3 rail "Bullet 2000E" shift lever assembly for a Mallock. Same as the original Elan trannys Actual lever shape not important. Any laying around out there? Thanks Chris D
Joe Petty Posted March 27, 2020 Posted March 27, 2020 Are you going to use this with the 3 bolt adapter at the end of the tailhousing (Integral Remote) or the 4 bolt adapter near the front of the tailhousing? My experience is that this one will only work with the 4 bolt adapter setup.
SENC Posted March 28, 2020 Posted March 28, 2020 Ray at rdent.com in the US and Steve at sjsportscars in the UK had them, at last check. Not cheap, though.
escondidoron Posted March 28, 2020 Posted March 28, 2020 Here's a long shot that might be worth a try. There's a gentleman near me that has a bunch of Cortina parts. He pretty much runs adverts continuously on the local craigslist: https://sandiego.craigslist.org/nsd/pts/d/vista-cortina-hub-caps/7097798961.html I've purchased a number of items from him over the years for my various Cortina, Lotus and Seven projects. The last item I bought from him was a transmission main case a while back. His name is Phil.
Chris D Posted April 6, 2020 Author Posted April 6, 2020 Are you going to use this with the 3 bolt adapter at the end of the tailhousing (Integral Remote) or the 4 bolt adapter near the front of the tailhousing? My experience is that this one will only work with the 4 bolt adapter setup. Correct. The 1/2 ball mounts directly to the top of the box cover with a round circular cone - not shown - but I need that too. The cone that supports the lever in place threads in the the ~ 4" x6" - 4 bolt, top cover. thnaks, Cd
