I am putting my car up again,going to go to something with windows and A/C!! I had a mishap a couple weeks ago and the drivers top front shock mount broke-thank you Michigan roads. I have since had the mounts welded AND reinforced on BOTH sides and feel it should not be an issue again. Unfortunately when this happened it caused some damage to the nose,I have decided to put TWO prices on the car-one if it goes as-is and one if I have the nose fixed (BTW,a new nose from Kinetic is 200 bucks) The car has been completely completely dialed in and is located in Michigan. Turbo Miata power with 286 crank horsepower and the car weighs 1300 lb - definitely very fun to drive. This is my third
Locost and definitely the best of the three. There is a couple of stress cracks in rear fenders-the previous owner had the car too low in rear and the tires were hitting the inside of the fenders-the car has since been raised and the cracks have not progressed in almost two years of ownership. Car handles beautifully on Bridgestone RE71 tires and is as fast as most other cars in a straight line. I have installed full carbon fiber front fenders and I also have the original fiberglass fenders that will go with the car. Miata rear suspension along with Miata brakes, the car stops and goes very well. The drivers seat is adjustable and the car will fit a taller driver without a problem.
Locost Seven Miata Turbo, Street Legal, 240whp
REGISTERED AS A 1972 Lotus-should be easy to get registered in most states
Clear title,no leins
Specs:
"Car has 2800 miles on it since build"
Book-sized frame
1996 1.8L Miata engine
Miata 5-speed manual
240 RWHP and 210 RWTQ
Drivetrain:
Spec Stage 3 clutch
T3/T4 Turbo
Tec-S Electromotive Fuel Management with direct fire ignition (Tuned on Mustang Dyno at VeryCoolParts.com)
4.30 Torsen LSD Rear differential (IRS)
15 Gallon RCI fuel cell
.095 DOM roll bar
Suspension/Wheels: coilover shocks,
full Miata rear subframe and suspension
15x7 alloy wheels
205/50/15 R-compound tires Bridgestones
Interior:
Speedhut custom gauges (turbo boost, speedo, tach, water temp, oil press, voltmeter, fuel level)
Kirkey Racing seats
4-point camlock harnesses
Fully carpeted interior and center console
Street equipment:
H4 headlights
Brake lights
Reverse lights
Turn signals with factory Miata cancel function (OEM Miata steering column)
BUILD THREAD: http://www.locostusa.com/forums/viewtopic.php?f=35&t=9336
ONE MORE THING-MIKE STAYS WITH ME-HE IS MY MASCOT!!!
As-Is price = $13,000.00
Repaired nose price= $14,000.00
Call Rich at 313-377-9542
Edited by spitfun
  • 1 year later...
On 2/5/2022 at 7:13 AM, Tricky Ricky said:
I'm looking for a used locost for sale need not run, don't want a wreck; looking for a new project; Doesn't even need an engine or transmission. Thanks Richard
Where are you located?  Any specifics you're looking for?  You might want to start your own thread with some details under Cars Wanted https://usa7s.net/ips/forum/38-cars-wanted/
