I am replacing the rear lights and looking for this connector
Any pointers as to what type or where to get a couple?
Thanks Steve
A few years ago I wanted to match up the factory headlight and running light/turn signal light connectors (that were similar in appearance the one in your photo). While I eventually did track down the company that produced them it ultimately ended up being easier to buy the needed bits from Caterham.
Steve,
I just purchased some of those econoseal J series connectors from this place: https://www.corsa-technic.com/category.php?category_id=109
I ended up getting several 4-way connectors and some extra pins and seals just in case. The prices seemed decent and I had the parts in less than a week. Could have been 3-4 days but can't remember. I'd buy from them again. Hope this helps.
Thanks ended up swapping them out for weatherpacks it is what I used for most other connections I replaced
Weatherpacks are a lot easier to source, that's for sure.
Steve,
Man wish I had come across this site before.. I rewired the whole dash with weatherpacks due to my OCD every time I took the scuttle off and saw the spaghetti of jumbled wires.
At the time I thought the Weaterpacks were kinda clunky and big (I wired each circuit to it's own plug), now looking at these I could of used there wire to board Series and made it much neater.
So now the next project is to rewire the whole thing again using this option
https://www.corsa-technic.com/item.php?item_id=622
(That OCD is nagging at me again)
