KryptonR500 Posted November 1, 2020 Author Share Posted November 1, 2020 Good reading above. Thanks KitCat for your message. My project stalled (normal reasons), so need to get back on it. I can confirm that my R500D engine has the double spring set-up... sounds unusual based on the comments above. I was thinking of trying to find the original builder as it was done here in the states. For info, I have never tracked the car (4 years of ownership), but the previous owner did some. I don’t believe I’ve taken it over 8,000rpm, as I was aware of issue. The failure happened low rpm pulling away; the only thing that I did differently on that day was giving it some unloaded revs when static (perhaps 6,000 - 7,000rpm). The Belmont Turner (Tom) has advised he’ll need access to the ECU in order to set up the vernier cam chain pulleys and tune; this is an MBE 39L067A. Does anyone know about this? Link to comment Share on other sites More sharing options...
JohnCh Posted November 1, 2020 Share Posted November 1, 2020 He'll need access to the ECU if he's making any deviation from the factory configuration: different cams, cam timing, compression ratio, etc that require map alterations, or if he's simply planning to put it on the dyno to optimize the torque curve, idle, or drivability for your specific engine. Dyno tuning is always a good idea, particularly if you have a person who knowns what he's doing. If, however, the shop is only reassembling the head and timing the cams, that's purely mechanical work and doesn't require ECU access. To complicate matters, Caterham generally delivered locked ECUs, so access may not even be an option. Someone here should know the answer for your particular unit. -John Link to comment Share on other sites More sharing options...
Croc Posted November 1, 2020 Share Posted November 1, 2020 If Caterham supplied the ECU then it is locked. Some owners sourced unlocked units independently of Caterham. No way to tell until you hook it up and try to chat with it. I suspect it is locked - I found it listed on Caterham Japan parts site: https://www.caterhamparts.jp/search/?category=120&t=20190405114020 SBD in the UK sells the bits to talk to the ECU - the proprietary cable/laptop adapter cable plus you can download Easimap software off their website. But then after spending that money you could discover it is locked. SBD will not give out the password to unlock the ECU but you may find someone on here who knows it. Someone on the forum may have the cable to sell/lend for you to test without resorting to SBD. SBD will do tuning of Caterham ECUs remotely. So you buy the kit to talk to it, take it to a local dyno place, have the dyno shop guys run the dyno and SBD will then run the software to tune it from the UK. They will want a wideband lamda for that exercise. Has been done by quite a few Caterham owners on here with good results. I think US-based Caterham dealers take the same approach or just sell you a new locked ECU off the shelf - checking with them will confirm. The alternative is scrap the existing ECU and go for a new brand ECU of your choosing. Link to comment Share on other sites More sharing options...
Shortshift Posted November 10, 2020 Share Posted November 10, 2020 To add to what Mike has written above. Caterham's ECUs are encrypted, so technically not locked but the effect is the same as they cannot easily be accessed and remapped. In the UK there are one or two tuners who can remap these encrypted ECUs including Steve Greenhalgh of "two Steve's" fame. Most rolling road operators cannot do this, however, with the common work-around being the sale of a new, open ECU that can be mapped as required. Makes it a costly rolling road/remapping session, unless you have other reasons for wanting to change or upgrade your ECU. The SBD/Easimap dongle and connector that Mike referred to will allow you to read certain parameters from MBE ECUs (including Caterham Cars encrypted units) such as lambda, temperatures, rpms, throttle (tps) position, etc etc., in real time. It's a useful tool to help with fault finding and for setting up. But it cannot be used on an encrypted ECU to adjust mapping. James Link to comment Share on other sites More sharing options...
KryptonR500 Posted August 5, 2021 Author Share Posted August 5, 2021 Hi guys, Summary of valve spring history as I understand it. 1) Kent parallel spring 38E051A, failures reported. 2) Cosworth conical spring 38E051B (2010/2011 from discussion above), but I believe supply changed to Kent at some point. 3) The 420R race regulations state that both the above can be replaced by 30E365A, which is the spec currently recommended by Caterham. Not sure if this is parallel or conical. John, perhaps the single spring fitted on your build were the newer 30E365A, not the 38E051A If anyone has any info on these, please let me know. Doesn’t sound like the “double” springs were ever Caterham standard supply. Link to comment Share on other sites More sharing options...
Croc Posted August 5, 2021 Share Posted August 5, 2021 @KryptonR500 By chance did you buy this Caterham off Ron? It looks like his old R500 and there were very few brought into the USA in that color. If so I have a build photo plus one of its entertaining shakedown drive in Denver. Link to comment Share on other sites More sharing options...
