Good Morning,
My Seven arrived in boxes as a kit for the first owner.
There is nothing in the manual about attaching the arm rest.
It is worn out and needs to be refurbished.
Anyone recall how it comes off?
Thanks,
Tony
On my 1998 Cat, it just pulls off.  No fasteners, it’s just a pressure fit.  One caveat.  My Cat has no carpeting on the tunnel walls, so not sure if that would change how the tunnel cover is attached.
Steve
My 2002 SV has carpet on the tunnel, the cover is a press fit. It still requires some wrestling between the shifter, brake lever and seats.
My 1989 S3 has a carpeted tunnel. The armrest is screwed to two aluminum straps that themselves are screwed to the sides of the tunnel under the carpet.
