Caterham Fuel Pressure Regulator
On the newer Caterhams with returnless fuel injection and the in-tank pump, do they control fuel pressure via voltage adjustments to the pump, or is there an integral mechanical fuel pressure regulator in the tank?  I'll need a more powerful pump to address hp levels on my incoming Caterham and am assessing options: keep things returnless with a higher capacity in-tank pump, or go with a return system with external pump. I'm leaning towards the latter, but would like to understand the stock system a little better before making any decisions.
Thanks,
John
Link to post
Assuming Caterham is using the same pump consistently, yours will be from an earlier European spec Ford Focus, part number BV61-9H307.  My understanding is the ECU controls the pump voltage rather than a mechanical regulator.
Link to post
Thanks Greg, that's what I figured and makes the decision easier given I'm running a different ECU.  An external set up with return and inline regulator won't require ecu programming so that aspect is easier, as are troubleshooting if things go wrong, and replacing parts if they do.  A little more weight and not as elegant as in-tank returnless, but probably a better choice for me.
Thanks,
John
Link to post
Glad to actually have a little info to share back.  If there is a future where I replace the current pump, I would go external too for all of the reasons mentioned.
Link to post
Who knows, you might get tapped to help me install mine and will then have first hand experience on how to do it :)
Link to post
I've been taking notes of your planned engine build and I've got a lot of pictures of CatKong so a little hands-on would turn piracy into collaboration. :classic_smile:
Link to post
Hmm..  Maybe we should have a local field trip to view CatKong.  I have a custom "I'd rather be driving a Westfield" license plate frame I need install on the rear of that car.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
