Starter Solenoid?
Everything I've touched this weekend has broken: this afternoon the seven's starter motor died (again). A similar failure occurred about 3-4years ago (motor spins but pinion doesn't engage flywheel).  It's the stock/standard duralast ford focus starter for my 2L duratec. I do have a Odyssey battery.
I'v been lead to believe this is a solenoid problem, does this sound correct?
Is this just bad luck or is there something I should check/fix that could be causing this to prematurely fail?
thanks.
Link to post
If the starter motor spins the solenoid is working. It sounds to me like the issue is with the pinion gear engagement. Was the starter weak before it failed? I don't know how the pinion gear gets pushed towards the flywheel, but if it is purely mechanical it could simply be that it needs a good cleaning/degreasing.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
