Hello,
I need to pull my X Flow lump for a seal refresh as Im sure they're from original build in 85.
I would like those block shipping side stands for bench work.
Im willing to return them on a lend.
Not available at Pegasus for a while.
Thanks
Scott
In Houston, Tx.
Edited by IamScotticus
I just made a mount for my engine stand. A piece of tube to fit stand with a plate welded on end, drilled to bolt on side of block. Put it on left side mount, and you can spin the motor and get to everything. Using the shipping stands seems like a real PITA, especially for getting at the pan gasket.
Charlie
Charlie
Good point! It's not too hard to find an engine stand on Craigslist or, dare I say, Harbor Freight.
Charlie
Charlie,  that is also in the plan for working on the mains.  I was going to do a search to see if those were available commercially or part of a stand kit.  Perhaps you have gone down that road already?
Yes, buying a work stand is the easy part.  Ive seen several xflow builders on utubes using stands with side mounts.  mostly English.
