Looking for the following:
- S3 Sidescreens
- 13 inch wheels (will consider both equal size and staggered)
- S3 Caterham Leather Seat with Headrest
Please let me know if you have any of these laying around.
Thanks
Edited by linenoise
no longer need seat
I have five original aluminum wheels from a 1984 Caterham if you are interested, these are not perfect, but they are straight and true. Let me know if you are interested. I’m located in New Hampshire so shipping could be a bit pricey.
Regards
  • 10 months later...
still in the market for:
- S3 Sidescreens
Rims with the right width, offset, and bolt circle are tough to find in the States. My understanding is the correct wheel for the front (and rear if not staggering) is 4x108/4.25", +et18 /4.21" back space, and 13x6. You might consider having them made to spec then have them painted:
 https://www.diamondracingwheels.com/index.php/racing-wheels/mini-stock-series
I don't know if cat ever switched to hub centric hubs for rim piloting and I'd check the runout on the new wheels before installation.
  • 7 months later...
  • 4 weeks later...
A friend of mine has 4 of these. Are they what you are looking for?
Edited by Vinman1
Thanks for posting -- those are a bit skinny, I'm looking for four 13x6s or two 13x6s and two 13x8s.
  • 4 weeks later...
I have four 13"  Kodiak lightweight 3 piece wheels.  I need to remove the slicks to measure them correctly and be sure they run true.  Current tire size is 7" on front, 8" on rear.
Used on my 2001 build Caterham.
With the slicks each weighs about 20 lbs. and the lower rotational inertia really liven up the car.
I used them only for track days.  Never crashed or bent but I will have them spun up when I remove the tires.
Located in Newbury Park CA.
Doug
805-402-1225
doug@tidsales.com
Edited by Doug7L
