I'm in the process of cleaning up 35 years worth of electrical weirdness in my engine bay.  I've got a cutoff switch with a relay to ground the alternator output through a resistor.  When I got the car the resistor was taped to the starter lead, but my intention is to put it in a little holder and stick it to the firewall, but I wonder if that's the best place.  for those of you with kill switches with the relay, where do you put your resistors?
