Deman USA Posted May 10, 2023 Posted May 10, 2023 Hi gents im looking to see if these two connectors are needed and if so where they plug into online shows green connector plugging into an ecu but don’t see ok ein my engine bay
11Budlite Posted May 10, 2023 Posted May 10, 2023 I'm pretty sure that green connector goes to the MAP sensor. Just found a thread on it: Maybe this has something to do with your WOT issue? 1
inchoate Posted May 10, 2023 Posted May 10, 2023 the black connector looks like a connector I've encountered for a Bosch knock sensor. Don't know much about Sigmas though.
11Budlite Posted May 10, 2023 Posted May 10, 2023 I'm pretty sure I have a spare black connector that's not used on my car too. Can't remember what it's used for though, Duratec dry sump maybe?
Deman USA Posted May 10, 2023 Author Posted May 10, 2023 6 hours ago, 11Budlite said: I'm pretty sure that green connector goes to the MAP sensor. Just found a thread on it: Maybe this has something to do with your WOT issue? I was hoping it was the issue when i cam across the same post last night but I do not see anywhere for the life of me a module or plug for this to connect to
