Duratec exhaust manifold gasket
I'm looking for an exhaust manifold gasket without the tail end for the EGR cutout. When the head was recently at the machine shop for new valves, I had them weld in the outer edge of the #4 port in an effort to balance the exhaust flow a bit more (reducing the dead volume of the #4 exhaust passage). Nothing like striving for that last micoblivet of horsepower! Cometic makes one (C48411-064) and while I have ordered  it (end of December, maybe early January), I am still hoping to find one in stock somewhere. The alternative is even more improbable. SCE made one as well (SCE 223084). Unfortunately, they went into bankruptcy during the pandemic and got purchased by another European firm. They no longer offer them.
Can anyone think of another option?
Thanks
You could:
1) use two standard graphite gaskets cut across the center bolt hole to butt together.
2) use copper or aluminum .050" sheet to make a reusable gasket.
@papak, Apple's ,heic format is not supported by the forum.  These typically convert to a jpeg when emailed from an iPhone or when uploaded to the forum from an iPhone (at least for me).  However, if you are using a Mac, it may not do that and you'll need to save as a .jpeg before uploading.
