Timothy Keith-Lucas Posted May 11, 2024 Posted May 11, 2024 Is there a port for a mechanical tachometer, or a way of rigging one, on the Austin etc. 948cc engine? I've got a digital run off a spark plug lead, and the original electrical tach which I've modernized, but the plain reliability of a mechanical tach is appealing. Any ideas appreciated.
7Westfield Posted May 11, 2024 Posted May 11, 2024 (edited) The 948 Sprites used a gearbox from the back end of the generator. You'll know if yours is right if it has a male thread sticking out the back end. A gearbox goes on there, and then the cable https://mossmotors.com/spm-088a-generator part #18, same drive cable as speedo Edited May 11, 2024 by 7Westfield
Timothy Keith-Lucas Posted May 11, 2024 Author Posted May 11, 2024 Wonderful! So it's under the projection out the back end labelled "OIL". I will pursue said, and thank you.
Timothy Keith-Lucas Posted May 11, 2024 Author Posted May 11, 2024 Ooops. No joy. No threads under the cover. Sounds like a new generator is in my future if I want a mechanical tach.
7Westfield Posted May 11, 2024 Posted May 11, 2024 I think Spridgets were the only use of that generator the shaft and rear plate are different if you have an oil port, I think you have the regular one after all, you don't need a tach in an A40.............. and then, you need the tach for a spridget
sagamore Posted May 13, 2024 Posted May 13, 2024 I have a Smiths mechanical tachometer running off the camshaft. It required modification to the front cover and to the camshaft retaining nut. This in turn requires modifying the rocker cover because the original crankcase vent is lost. It's pretty cool in a luddite sort of way, but a Stack chronometric would have done the same thing tapping off the coil signal. 1
Timothy Keith-Lucas Posted May 14, 2024 Author Posted May 14, 2024 Thanks. Interesting approach. At the moment I'm trying to resurrect my positive ground original. I would prefer a mechanical unit, for simplicity and accuracy. The electrical unit has lots of problems, but re-wiring may solve them. I have not found a generator with the mechanical take-off, complicated by my 7 being positive ground.
7Westfield Posted May 14, 2024 Posted May 14, 2024 (edited) if you want to shell out bucks, moss sells the generators it's easy to swap polarity on a gen you might even have to set it on a new one what do you have on the car that would be polarity sensitive? I think I just swapped the wires on the ignition coil when I converted my bugeye, back in the 70's and maybe the fuel gauge, but being resistance based, it might not care light bulbs and starters don't care..... Edited May 14, 2024 by 7Westfield
jbcollier Posted May 15, 2024 Posted May 15, 2024 Mechanical tachs are not more accurate than electric/electronic ones. Had a Climax powered Turner come in with the owner saying there was no power. The problem? His mechanical tach read 3k low. Get a tach repair module for the tach you have. It will be fine.
IamScotticus Posted May 15, 2024 Posted May 15, 2024 On 5/11/2024 at 9:04 AM, Timothy Keith-Lucas said: Ooops. No joy. No threads under the cover. Sounds like a new generator is in my future if I want a mechanical tach. Or a voltage regulator?
