mr.vman Posted July 21, 2024 Posted July 21, 2024 (edited) Attempting to do a trial assembly of my S4 Seven. New fiberglass body. Question (no doubt more to come). The stamped bracket that appears to hold the steering column. Number 19 in the parts list. How does the bracket fit? in the fiberglass lip below the speedometer and tachometer? There is a wide "U" area below the speedometer and tachometer that the steering column fits into. Is fiberglass removed to fit the bracket? Edited July 22, 2024 by JohnCh Fixed unsupported .heic images
MV8 Posted July 22, 2024 Posted July 22, 2024 (edited) The bracket goes on top of the fiberglass flange and the column clamp hangs from it. Edited July 22, 2024 by MV8 1
JohnCh Posted July 22, 2024 Posted July 22, 2024 Thanks @MV8. @mr.vman I fixed the images for you, but please read the help guide MV8 pasted above so you can do this yourself in the future. Thans, John
